Shooter63
| posted on 13/1/18 at 10:29 AM |
Su hif carb
A bit of a long shot on here but has anybody got a su hif carb knocking about they don't need, all I need is part of the linkage but it's
not available from anywhere, most parts are but not the linkage bit. Hif 38 or 44 will be ok as I'm pretty sure the part I need is universally
fitted as long as it's from a single carb set up ( twins have different linkage set ups)
Shooter
martin500
| posted on 13/1/18 at 12:00 PM |
Have you tried Burlen? http://sucarb.co.uk/linkage-parts.html
Shooter63
| posted on 13/1/18 at 01:57 PM |
They were the first people I tried, no luck I'm afraid, but thanks
Shooter
40inches
| posted on 13/1/18 at 03:47 PM |
This any good https://www.minisport.com/lzx1739-hif-carburettor-linkage.html
| posted on 13/1/18 at 04:09 PM |
Might be worth asking on a Mini or maybe the GTM owners forum?
Shooter63
| posted on 13/1/18 at 05:52 PM |
Thanks but that is the lever I have, it's the inner one I need
Shooter
redturner
| posted on 13/1/18 at 06:13 PM |
That is the one that I use on my R1 carbs instead of the throttle pot...........
| posted on 14/1/18 at 04:07 PM |
I've got a v8 manifold with two su on, what bit do you need?
