Author: Subject: 7" or 7.5" Cosworth LSD
sammini7
posted on 13/1/18 at 02:29 PM Reply With Quote
Hi guys,
Need some help, what Cosworth rear LSD differential should I choose a 7" or 7.5"? The 7" is £150 cheaper second hand and currently my thoughts are go with a 7'. Is There any reason I should choose the 7.5" over the 7"?
Please Help
Ps Happy New Year Building to you all!!!
[Edited on 13/1/18 by sammini7]
CosKev3
posted on 13/1/18 at 08:05 PM Reply With Quote
Will both fit in your chassis?
7 inch is plenty strong enough in a lightweight car,bigger is stronger.Hence Ford used 9 inch diffs in GrpA cosworth etc.
fregis
posted on 13/1/18 at 08:39 PM Reply With Quote
7 is lighter and but have smaller LSD,
7.5 have more weight, but bigger LSD
cosworth 7.5 dif have bigger lobro fiting, so can be problem fiting with standart sierra or granada driveshaft - first check if fits
If LSD condition is ok - is not need go to 7.5", but car is old.... i have one car 7.5 another 7 - both not working perfect
about body:
7 -7.5 diff body main different is top muont (left size 0.5 wider), sometimes quite easy to fit
p.s. i dont remmber kg, but i can try to weight it
[Edited on 13/1/18 by fregis]
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
sammini7
posted on 14/1/18 at 01:06 PM Reply With Quote
Many thanks for all your help I have identified my chassis is setup for a 7" diff
[Edited on 14/1/18 by sammini7]
