Author: Subject: Diff rebuild who to use and quaife upgrade???
Bigboystoys
posted on 19/1/18 at 09:43 PM Reply With Quote
Currently changing my clutch so while engine and gearbox are out I'm also going to pull my 7.5" lsd ford diff out for a refresh as it's just started getting a little whiney. Question is who are people using and also is it worth fitting a quaife lsd whike I'm at it? I use car on road with occasional track day.
Many thanks
Sam
CosKev3
posted on 19/1/18 at 10:58 PM Reply With Quote
Dave Rae Transmissions is good with the Sierra diffs.
If you want to retain the Ford Viscous LSD Bara Motorsport can change the viscous fluid to make the diff work better in our lightweight cars.
If you do go for a quaife you will need to buy the stupidly expensive output shafts off quaife to retain your bolt on drive shafts,iirc they are circa £350.
[Edited on 19/1/18 by CosKev3]
mackei23b
posted on 22/1/18 at 08:19 AM Reply With Quote
Road and Race do all the Caterham diffs, they come well recommended.
Bigboystoys
posted on 22/1/18 at 10:19 AM Reply With Quote
Thanks for replys it's off to road and race Friday as it's not too far away
