Author: Subject: VIN stamping
craigdiver
posted on 15/3/18 at 05:42 PM Reply With Quote
VIN stamping
Had a go at stamping my DVLA issue VIN onto my 25mm box section chassis with 6mm punches - just deforms and doesn’t imprint very well. Got a quote for a bit of steel engraved with VIN that I could weld on - £35! OUCH!
How did you get your VIN onto your chassis?
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
monkeyarms
posted on 15/3/18 at 05:56 PM Reply With Quote
Just punched mine on. You could punch onto thin sheet sheet steel then weld onto chassis.
craigdiver
posted on 15/3/18 at 05:59 PM Reply With Quote
Did give that a go, but wasn’t that neat trying to line up each punch - might knock up a jig to use as a straight edge and get character spacing consistent.
Badger_McLetcher
posted on 15/3/18 at 07:49 PM Reply With Quote
Draw up a grid on the plate with boxes just a bit larger than each letter, then punch one letter in each box. Makes it look much neater
[Edited on 15/3/18 by Badger_McLetcher]
If dysfunction is a function, then I must be some kind of genius.
ken555
posted on 15/3/18 at 10:01 PM Reply With Quote
Use the wood as a straight edge of the punch, a microfibre cloth on the 2nd bit of wood as a cushion to allow just enough depth.
Daf
posted on 15/3/18 at 10:28 PM Reply With Quote
I used an engraving tool, bought off ebay for 15 quid and a childs letter stencil. Worked really well cor me.
mikeb
posted on 15/3/18 at 10:33 PM Reply With Quote
I used a cheap engraving tool that came with a letter stencil, did the job ok and looks pretty neat.
AdrianH
posted on 16/3/18 at 12:23 AM Reply With Quote
Machined Dummy Vin no.
This was around 8 years ago now I turned a mill bit down to a point to make an engraving bit and then engraved in a piece of 1 inch tube my chassis number, then it was one of the small stiffeners near the bulkhead.
Similar with an aluminium plate for the weights, model number etc although the plate Vin tag would have been probably better with a pre printed plate.
Do you know anyone local with a cnc mill set-up that could help?
Adrian
[Edited on 16-3-18 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
Build diary at http://www.tamarisktechnicals.com/pages/roadster.html
907
posted on 16/3/18 at 04:29 AM Reply With Quote
My solution was to stamp a piece of sheet, cut a slot in the chassis then cut down the stamped sheet to match the slot.
I then welded the numbered sheet into the chassis slot so that it was flush. Sanded the welds off with a flap wheel and
no one would know that I hadn't stamped the chassis.
Mmm, slight hiccup, as I then had to cut a slot in the ally side panel as the panel covered the number. Another senior moment.
Paul G
plate to be welded on chassis
VIN number onto chassis
SJ
posted on 16/3/18 at 07:26 AM Reply With Quote
I had the same issue so stamped onto a bit of thicker steel bar - 4mm ish, and welded it onto the chassis rail. Made the job much easier
posted on 16/3/18 at 10:37 AM Reply With Quote
IIRC correctly I punched mine on the edge of 25mm box section on my MK Indy. Punching it near the edge stopped the box section deforming. The characters weren't in a laser straight line, but perfectly adequate and passed SVA without an issue. Also a fact that once stamped and SVA checked I didn't look at it again - it was under the bonnet anyway
