Author: Subject: Zetec on bike carbs cant suss misfire
demonbarber33
posted on 25/5/18 at 08:11 PM Reply With Quote
Hi im at a loss have misfire full throttle in 4 gear aprox 6.5k.
Changed coil leads plugs, fuel pump checked tank breather, thought was fuel but now maybe electrics.
DO edis units play up? Crank sensor? Lost now! Help!
avagolen
posted on 25/5/18 at 09:15 PM Reply With Quote
Fuel flow?
Does your fuel pump have enough flow rate to supply fuel at those revs and load?
snippy
posted on 25/5/18 at 09:31 PM Reply With Quote
I had the same problem on mine a couple of years ago. Same set up, zetec on zx6r carbs. It wasn`t getting enough fuel at high revs causing it to stutter badly. I was running a bike fuel pump and also a malpassi fuel regulator. I removed the fuel regulator which cured it.
demonbarber33
posted on 25/5/18 at 09:46 PM Reply With Quote
Got good fuel flow 1300ml per minute,Car used to rev to 7200 no problem
johnemms
posted on 26/5/18 at 09:41 AM Reply With Quote
Whats your AFR at WOT
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
Angel Acevedo
posted on 26/5/18 at 02:07 PM Reply With Quote
Does it revs up to 7200??
Or gets to 6.5K only?
I can´t make what you have changed, Coil, leads and plugs?
Does it feels like a rev limiter?
Coil starting to fail may give that failure mode as well as valve float due to weakened spring?
HTH
demonbarber33
posted on 26/5/18 at 05:36 PM Reply With Quote
I’ve changed all electrics 😳
Revs out in lower gears no problem,feels like limiter
dan8400
posted on 26/5/18 at 05:55 PM Reply With Quote
I had the same set up and , as mentioned, it was fuel trouble.
I changed all the things you changed chasing it.
Mine was down to crap in the carbs (blocked jet). Quick strip down and plenty of carb cleaner and it was right as rain.
Seems to be fuel trouble one way or another.
Good luck with the fix
Dan
Hey - That's Journey!!!
Ugg10
posted on 26/5/18 at 06:29 PM Reply With Quote
Did you use shielded cable for the crank sensor and have earthed it. I had a similar problem but at lower revs with the engine stuttering but this was on injection, it was interference with the crank sensor cable.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
demonbarber33
posted on 27/5/18 at 02:17 PM Reply With Quote
Only thing I’ve found is a bit of debris in one of the pilot jets, gonna check the needle valve seat filters to see if blocked up at all. Happy days!
Schrodinger
posted on 27/5/18 at 04:25 PM Reply With Quote
What ECU are you using for ignition?
Keith
Aviemore
demonbarber33
posted on 27/5/18 at 06:07 PM Reply With Quote
Megajolt but same problem running just on edis
Schrodinger
posted on 27/5/18 at 07:07 PM Reply With Quote
Are you sure it is not a soft cut out in the megajolt
Keith
Aviemore
demonbarber33
posted on 27/5/18 at 09:10 PM Reply With Quote
Yep set at 7500 rpm revs out in lower gears
