Author: Subject: Zx9 E wiring
matt.c
posted on 13/6/18 at 10:31 AM Reply With Quote
Zx9 E wiring
Long shot but has anyone got a diagram on how to wire up a zx9E engine please? Got one fitted but cant get it to fire. Just want to check how others have wired it.
Many thanks for your time guys.
Matt
gremlin1234
posted on 13/6/18 at 11:44 AM Reply With Quote
a quick search found
http://serwer.robert.webd.pl:30/manual/Kawasaki_ZX_9R_(ZX900_C1,D1)_98_Service_Manual_ENG.pdf
I have seen common problems associated with the stand position switch. (yea you don't have a stand, need to bypass the switch)
minitici
posted on 14/6/18 at 09:23 AM Reply With Quote
Has your engine ever run in the car?
If it is a new installation and you are not using the bike's ignition switch, you will need to fit a 100 Ohm resistor into the grey wire feeding to the CDI/ECU.
As stated above, the side stand switch also needs to be linked out.
wylliezx9r
posted on 14/6/18 at 11:41 AM Reply With Quote
From memory I believe the clutch switch also has to be shorted.
George Best
