Author: Subject: Steering Short Shaft and UJ Support Bearings
BigDawgV8
posted on 8/7/18 at 09:51 AM Reply With Quote
Morning All!
Coming to the end of a rechassis project and i’ve now got to get my head around relocating the steering short shaft.
The original layout used the Sierra column with a shortened Sierra short shaft.
This time round I need to add another shaft and u/j for clearance.
Rally Design do the shaft and u/j BUT I would obviously need to support the shaft.
I’m thinking something like a 2 piece nylon roll bar clamp or pillow bearing??
What have you peeps used in the past?
Advice with pics or links would be good.
Thanks in advance.
myke pocock
posted on 8/7/18 at 02:51 PM Reply With Quote
When I built my JC Midge I used a spherical rod end (rose joint) on a box pillar with a nut welded to the end for adjustment and a locking nut.
rash12
posted on 8/7/18 at 03:26 PM Reply With Quote
pillow block or rose joint
MikeR
posted on 9/7/18 at 01:36 PM Reply With Quote
due to my design i couldn't use a rod end both ends of the shaft had something on it. I got a anti roll bar clamp. Splits apart, fits snugly. Not been through IVA but i think its a good solution.
