Author: Subject: Mx 5 advice
dbaz293672
posted on 11/8/18 at 07:36 AM Reply With Quote
Mx 5 advice
Hi I am currently fitting a mx5 1800nb engine and box into my mk, I am then using a ford diff so I have 2 questions really
1, is there an adapter plate to take the mc prop to ford diff
2, shortened sump, does anyone have one as I can and the engine to sit as low as possible
JonBowden
posted on 11/8/18 at 03:28 PM Reply With Quote
I believe that it is normally advised to have a propshaft made for your application.
I think the cost is normally 200 ish
Jon
ianhurley20
posted on 12/8/18 at 09:03 AM Reply With Quote
I had an MX5 prop from my donor so sent it to (I think) Bailey Morris who cut it down, installed a sierra coupling and balanced it before returning, cost was 115. The important dimension for them is the distance from the very rear of the gearbox to the front face of the sierra diff flange, 650mm on mine if I remember correctly
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why!
dbaz293672
posted on 12/8/18 at 10:23 AM Reply With Quote
Brilliant thanks for that I will make contact got to get the engine and box in first then will know where we are at
