Author: Subject: Increasing centre bore on wheels
Quinten
posted on 30/8/18 at 09:33 PM Reply With Quote
I've bought a nice set of 13" wheels and have now discovered that my (live axle) rear hub has got a slight wider diameter (69mm) at the back, than at the front (67.1mm). The wheels I bought have a centre bore of 67.1mm but I can only run them with a spacer at the moment to get round the wider diameter at the back. Unfortunately it also means that due to my lardy weight the tyre on the driver side rubs on the wheel arch when I hit any sort of bump in the road.
So either get the hub turned down to 67.1mm or increasing the centre bore on two wheels to 69mm... Anyone in Northants able to help?
snapper
posted on 31/8/18 at 07:21 AM Reply With Quote
Getting wheels done would be easier, some warehouse based wheel refurb companies can do it, but reducing the hub spigots give you the option of using spigot spacers in the future if you go back to larger spigot hole wheels
I eat to survive
I drink to forget
AdamR20
posted on 31/8/18 at 08:05 AM Reply With Quote
I'd have thought cheaper and easier to pop the half shafts out and have the hubs turned down. Anyone with a big lathe can then do it, bung some guy at a machine shop £10 to do it on his lunch break?
posted on 31/8/18 at 10:59 AM Reply With Quote
I'd favour having the centre bore of the wheels enlarged to Ø69 to fit the hubs. Then you (or subsquent owner(s)) can fit the right centre bore wheels in the future.
Quinten
posted on 31/8/18 at 05:11 PM Reply With Quote
To me "popping out the halfshafts" doesn't sound so easy... But that would be my ideal way of resolving the issue.
nero1701
posted on 31/8/18 at 05:18 PM Reply With Quote
I've had the same issue in the past, I had a set of Mini wheels and wanted to use them on a mk2 golf..
Take the wheels to any eng workshop.
Milling machine with a 360 degree rotating bed should do the trick.
PAULD
posted on 31/8/18 at 08:32 PM Reply With Quote
I can do either for you but preferably the halfshafts.
Quinten
posted on 31/8/18 at 09:32 PM Reply With Quote
I've looked at a few videos and removing the half shafts looks to be as simple as AdamR20 suggested. But putting them back in, does anything need replacing? Or any special tools needed?
Bearing in mind that the half shafts where (along with the axle and diff) completely refurbished last year...
Angel Acevedo
posted on 31/8/18 at 09:36 PM Reply With Quote
I would find out which center bore has more options available for your application and machine to suit. There are a few Internet sites that list them.
Also, having Hub machined to smaller size may be better than the other way around. At least on my narrow sighted mind...
AdamR20
posted on 1/9/18 at 09:30 AM Reply With Quote
Nothing special to replace, just some sealant for the bearing where it goes into the axle casing.
Have run the 'wrong' wheels (centre bore too big) on a 1 ton track car before, no issues. The wheel bolts / nuts give about 8 tons clamping force each at correct torque, no need for the lip on the hub really. Does help to centre the wheel when fitting though.
Quinten
posted on 1/9/18 at 09:47 AM Reply With Quote
This may help (found some old pictures from when I had to replace the brake cylinder)
The slightly raised lip on the hub is only there for the last 14mm. I'm assuming I would need to remove the studs too before it can be put on a machine?
When you say sealant, what sort of sealant? It's funny how I managed to do an engine swap ok, but these things still strike fear into my heart...
theprisioner
posted on 1/9/18 at 10:24 PM Reply With Quote
There is a device called a Mag Drill Cutter (Rotabroach) a type of Annular Cutter but very precise. It would be relatively easy to increase the size of spigot hole with relative precision. If you made a jig on a lathe, the jig would be a round bar with a 6.5mm hole to take the centre pin guide and the outside turned to the size of the existing spigot hole. . You would need a Mag Drill machine but these can be hired. You would also need a steel plate and attach it firmly to the alloy wheel in some way. The Mag drill cutter see eBay item number: 132487844795 A high risk approach because if you get it wrong you would have an unbalanced wheel, not nice to drive.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
AdamR20
posted on 2/9/18 at 06:48 AM Reply With Quote
Silicone sealant
You could leave the studs in. Happy to do the machining for you, but I am near Preston.
Edit: the 'stubs', where the wheels fit over, on your half shafts look unusually big / tall. I also have the same axle in my car and have it all apart at the moment, going to do some machining work on them today in fact!
[Edited on 2/9/18 by AdamR20]
Quinten
posted on 2/9/18 at 07:24 AM Reply With Quote
Thank for the offer Adam, but yes, Preston is just a little too far
It all sounds in the realm of do-it-yourself though, so I'm going to stop thinking about it, and just get on with it.
AdamR20
posted on 2/9/18 at 08:04 AM Reply With Quote
Good man, I'm sure you'll sort it. Could even knock the studs out and grind the lip back. Studs will go back in with a wheel nut and a load of washers.
Slimy38
posted on 2/9/18 at 08:20 AM Reply With Quote
Apologies for taking this in a slightly odd direction, but there is something I'd like to ask on this subject. Several people (and many websites) have suggested the centre bore isn't a critical part of keeping a wheel on a car. There is a view that once the wheel is attached to the car with the bolts/nuts, that the wheel is centralised and not going anywhere. Obviously it helps with getting the wheel on in the first place, but after that not so much.
As people on here are a little more knowledgeable than the average internet keyboard warrior, what is the right answer? Does it actually contribute to the wheel staying attached? or is the 100lbft of wheel nut torque and the surface area of the hub sufficient to keep the wheel solid under braking and cornering?
Just looking at the answers here it looks like AdamR20 has been in this situation with no ill effects, any others?
Quinten
posted on 2/9/18 at 11:09 AM Reply With Quote
Well, that was fun... not. No amount of trying to shock it, got it out. Next weekend I'll try to give myself more space inside the garage so I can put more force into it. If that fails, it's back to plan a)
AdamR20
posted on 2/9/18 at 11:30 AM Reply With Quote
Got an old drum? Bolt it on 'backwards' then you can give it some welly from the back.
Quinten
posted on 2/9/18 at 11:56 AM Reply With Quote
Yeah, that's how I tried. Unfortunately, my garage is limited in space and I had put the car up on axle stand in the middle (so I could do both sides if I got that far), but that meant I had a very limited space at the side so I could not put my full weight/strength into it. I didn't want to do it outside where I've got plenty of space, in case it went pear shaped as I would then be left with a car on axle stands, unable to be moved inside overnight.
AdamR20
posted on 2/9/18 at 12:27 PM Reply With Quote
Good skills. You're a man who thinks ahead far more than I do
With a chunky hammer it should come free, the ones I just did wouldn't budge with all the usual tricks, but the backwards drum worked. They had been in there at least 25 years!
alfas
posted on 3/9/18 at 07:50 AM Reply With Quote
lets think this way:
who was first:
the halfshafts or the wheels?
which is the part that does not match? the wheels or the halfshafts?
for me (just for me, others might be different opinion) the answers are clear:
the halfsafts where first and the wheels do not match.
so i would never ever modify the halfshafts.
you can also put the wheels on a lathe and enlarge the innner bore.
much easier as you need to remove the wheels anyway...before you get access to the half-shafts.
AdamR20
posted on 3/9/18 at 07:56 AM Reply With Quote
I agree, but we are DIYers and have to be realistic I think! Who has a lathe capable of taking a 600mm diameter item in their garage? Or one that'll take 400mm and a tyre machine?
My point is, you can make these wheels fit perfectly safely using a 1/2" socket, a hammer and a grinder
Quinten
posted on 23/3/19 at 09:24 AM Reply With Quote
I know it's a fair few months since last update, but I like to close threads
After borrowing a sliding hammer the halfshafts came out straight away. Took them to a friend who had offered to machine them down but when he looked at them more closely, he spotted that it looked like there was a collar fitted that contained the raised lip.
So took them home again and after 5 minutes with the angle grinder got the collars off.
Halfshafts back in and car back on the road on its new wheels!
