Author: Subject: Elite Sequential and flatshift system
Rich J
posted on 11/10/18 at 05:53 PM Reply With Quote
For sale due to the need to fund a new project is this Elite IL200 6 speed box and closed loop flatshifter system
Very low mileage throughout its life and has zero miles on it now since its return from Elite a few weeks ago where it had a bearing upgrade carried out and one gear replaced (operator error the cause!). Invoice available.
Ratios give 130 mph at 8250rpm through a 4.4:1 diff and 13 wheels.
1x 23 tooth input shaft of standard length
New, slightly longer than original, reverse gear cable fitted and the original is also included.
The gearbox is filled with fresh oil ready to fit and another bottle is included ready for the next oil change.
The Elite made prop mates the gearbox to a large type flange as found on English and Atlas diffs.
Comes with Geartronics gear display and a pair of homemeade mounts which may help with your install.
Loads of associated paperwork to accompany the gearbox.
4000.
Bank transfer or cash on collection.
Also available is a Proshift Bump and Blip flatshift system.
Capable of clutchless up and down shifts using the included blipper. The operating cable on this could be changed to suit your application
More details here:
https://www.proshift.com/proshift_digital_closed_loop_bump_blip_system
Has potentiometer capable of measuring up to 50mm of travel.
All wiring and USB stick with install/set up information included.
Invoices for in excess of 2000.
1600 including postage
Can be collected from the SA19 post code area - 7 miles from the end of the M4
Alternatively I travel to Cardiff every few weeks on a Sunday so could meet at a mutually convenient time at junction 33
Rich J
posted on 13/10/18 at 07:14 PM Reply With Quote
Would do a deal on the box and flatshift system combined for 5000
Rich J
posted on 18/10/18 at 07:35 PM Reply With Quote
Both items listed separately on a well known auction site with no reserve - grab yourself a bargain
[Edited on 18/10/18 by Rich J]
femster87
posted on 21/10/18 at 12:43 PM Reply With Quote
Are the gears straight cut?
Rich J
posted on 23/10/18 at 06:15 PM Reply With Quote
Hi, No they're helical - thanks for asking
