Author: Subject: Rear bulkhead
Peter Perfect
posted on 28/10/18 at 09:36 PM Reply With Quote
Rear bulkhead
just a simple question, can the rear bulkhead be removable. I was thinking for accessibility to have a bulkhead that is fixed with self tapping screws to the chassis and b ody frame. would this pass iva
Howard
J666AYP
posted on 29/10/18 at 12:51 AM Reply With Quote
I can't see any issues with the IVA test. I would sway towards rivnuts over self tappers though.
Jay
minitici
posted on 29/10/18 at 10:02 AM Reply With Quote
I normally drill and tap the tubes M5 and fit socket headed button head screws.
posted on 29/10/18 at 10:25 AM Reply With Quote
On my MK Indy I made the top panels of the tunnel removable for access, but all other panels were rivetted in place. The cover of my GRP rear tub was removable should I have needed access, but I never did.
The rear bulkhead was a revitted in alloy panel. Ultimately (after removeing the seats) I could have quite easily dilled out the rivets and removed the bulkhead for access. Again I never had any need to do that though.
With top access, bottom access and wheel arch access there really wasn't anythign I couldn't get access to. Replacing the fuel tank would have taken some doing, but I fitted it and ran the engine up a few times before fitting the GRP rear tub. Aside from refuelling the vehicle I never needed to access the fuel tank.
Peter Perfect
posted on 29/10/18 at 09:46 PM Reply With Quote
Thanks guys , rivet nuts i think are the answer
Howard
Bluemoon
posted on 30/10/18 at 08:50 AM Reply With Quote
Bonded and riveted should help with the torsional stiffness of the chassis.. But Rivet nuts will do it if you must.
[Edited on 30/10/18 by Bluemoon]
