Author: Subject: Hayabusa Starter Relay
Rob55
posted on 27/12/18 at 09:19 PM Reply With Quote
Trying to wire a busa at the moment, using an MBE / SBD loom but am confused about the starter relay as it isnít part of that loom. I know the two big ring terminals go to the starter motor / battery cut off switch, but can anyone tell me what the four small pins go to?
posted on 28/12/18 at 11:24 AM Reply With Quote
Relays are normally used to reduce the amperage going through the switch , in your case the ignition or starter switch . Terminal 30 is battery positive 87 or 87a is switched live which would go to the starter solonoid 85 would be the switched feed and 86 would be earth . Don't think it matters too much which way 85 and 86 are wired , the relay will still work
CosKev3
posted on 28/12/18 at 05:39 PM Reply With Quote
When I went aftermarket ECU on my R1 I used a LandRover solenoid,so getting rid of all the original Yamaha wiring and relay.
minitici
posted on 29/12/18 at 10:52 AM Reply With Quote
Are you referring to an FIA battery Master Switch?
If so the four smaller terminals are a normally open and a normally closed pair of switches.
These are designed for one set to cut the ignition power to the coils to kill the engine.
The other pair are for attaching a 33 Ohm high power resistor to dump the residual power to ground from the alternator when the master switch is turned off.
You don't necessarily need to make these connections but they are there to ensure that the engine does not run on after the battery has been isolated and to stop you frying the alternator's diode pack.
CosKev3
posted on 29/12/18 at 12:02 PM Reply With Quote
I don't think so,it states 'hayabusa starter relay ' which is one of these;
https://www.mymotoparts.co.uk/p/suzuki-gsx-1300-r-hayabusa-2nd-gen-uk-2008-2014-starter-relay-each/?CAWELAID=120193280000050788&gclid=Cj0KCQiA05zh BRCMARIsACKDWjcbktIQbPGmmTnVCEdxS_BdkqUYxSypbragEXwlIsMykCSFGyGoDswaArNcEALw_wcB
[Edited on 29/12/18 by CosKev3]
