swanny
| posted on 19/3/19 at 09:51 AM |
Transit minibus
hello
does anyone on here run a new ish (17 onwards) transit minibus?
we are hirinjg onje for le mans this year and i wanted to check how easy it will be the remove a row or two of the seats to free up more space for
bikes etc.
paul
cliftyhanger
| posted on 19/3/19 at 11:32 AM |
Watch out for the rules on minibuses in the UK and Europe.
If you share the costs, it is (or used to be treated) as commercial, and a tacho etc required.
If over 3500kg max weight, the driver, even in the UK, needs D1 entitlement. Often not noticed...
Do some digging.... The easiest solution is a 8+1 driver sized vehicle. Not all hire places understand the rules
swanny
| posted on 19/3/19 at 11:53 AM |
luckily we are all old and have D1 on the licences!
I'll check the other stuff though, thanks
trextr7monkey
| posted on 20/3/19 at 05:26 PM |
We had a couple of minibuses at the school I worked at they were pretty new, we used to remove back seats to load up with wood and sheets of stuff,
just some spring loaded catches quick to take in and out. Biggest problem was finding somewhere safe to keep seats when out of the bus
Atb
Mike
PAUL FISHER
| posted on 21/3/19 at 07:54 AM |
They are just bolt in, you can just unbolt a couple of rows of seats, although there are quite a few bolts for each seat, as they have the seat belts
built into the frame of the seats, but a hours work should easily see the rear two rows removed.
[Edited on 21/3/19 by PAUL FISHER]
trextr7monkey
| posted on 21/3/19 at 09:49 AM |
No spanners involved on ours
owelly
| posted on 21/3/19 at 12:24 PM |
Just a heads-up: many hire companies stipulate that you can't alter or modify their vehicle without their permission. Perhaps ask them to remove
the seats before you collect?
http://www.ppcmag.co.uk
swanny
| posted on 21/3/19 at 01:35 PM |
hi Owelly,
I did ask them about it and they were cool with it. they've offered to take out the removable back row for us before we collect but were happy
for us to take the others out. I don't know whether it helped that we found them via a mutual friend of the MD but I was a bit surprised at how
ok they were with it.
paul
owelly
| posted on 21/3/19 at 04:28 PM |
Some say it's better to seek forgiveness, than to seek permission... I usually agree unless it costs me money. Great that you found an amicable
hire company.
| posted on 22/3/19 at 12:18 PM |
hire company.
I've been told the same - "seek forgiveness and not permission".
All well and good, but be careful of legalities and costs along the way!
