Author: Subject: Emissions test probe - how far into tailpipe?
JekRankin
posted on 1/5/19 at 11:14 AM Reply With Quote
How far does the emissions probe need to be inserted into the tailpipe for the emissions test?
I have a dB killer in mine, which means the probe can only be inserted about 100mm into the exhaust tailipe. Will that be enough?
Jek
russbost
posted on 1/5/19 at 12:40 PM Reply With Quote
No, it will almost certainly vary from station to station as I don't think they all have identical equipment, but I would say you need to allow at least 10" of free entry space, preferably 12"
JekRankin
posted on 1/5/19 at 01:22 PM Reply With Quote
Ah, oops. Don't think the db killer is wedged in there pretty tight. Are these usually installed at the entrance to the silencer?
Think i'll need to get a replacement tail pipe and live without the db killer. Anyone know where I can get a 45deg tailpipe with a nice rolled end for IVA?
Jek
russbost
posted on 1/5/19 at 05:09 PM Reply With Quote
dB killer needs to go in after the main silencer to allow room for gases to slow down & expand in the silencer, otherwise it's unlikely to be effective. Can you not simply add a section of tube with suitable rolled end to the existing pipe to allow the probe to read gases - it only needs to be there for IVA
JekRankin
posted on 1/5/19 at 08:06 PM Reply With Quote
Sadly there's no room in the Fury sill for what you suggest.
A 45 deg tail pipe is fitted directly into the silencer outlet, and it's in this tail pipe I've managed to get the DB killer stuck. At best, I've got 7" of free exhaust length to insert the probe.
Looks like i'll need to get another tailpipe and run without the DB killer.
Jek
ttalps2000
posted on 2/5/19 at 07:26 AM Reply With Quote
i initially put mine in on the tail pipe end, then had the same thought about the probe at IVA, so i swapped it to the manifold end, which made it even quieter, but it did screw my emissions and the engine didnt want to rev. Just squeezed through the emissions though!
russbost
posted on 2/5/19 at 07:43 AM Reply With Quote
Jek
Sounds as tho' the pipe is removable? Or are you going to cut off & weld a new one on? Either way, just put the Db killer into the rear end of the silencer b4 the 45 deg pipe goes back on, as ttalps has confirmed fitting in front of the silencer may cut noise, but actually chokes the engine off with a partially blocked exhaust - hence the emission probs he mentions
JekRankin
Unfortunately I can't fit mine at the manifold end because the cat is in the way. Only option would be to put it inside the silencer, where it may not be as effective. I think i'll chance it without it. Argh, it's never easy!
Jek
russbost
posted on 2/5/19 at 07:46 AM Reply With Quote
Fitting at the rear end of the silencer will be as effective as fitting in the tailpipe, but without strangling the engine, shouldn't affect emissions much either, tho' could tweak them one way or the other
[Edited on 2/5/19 by russbost]
40inches
posted on 2/5/19 at 08:34 AM Reply With Quote
I left the decibel killer off until the noise test, the examiner was fine with that.
They got the probe about 10" past the sharply bent outlet.
posted on 2/5/19 at 09:59 AM Reply With Quote
Not being able to insert the probe is likely to cause problems with the Lambda reading, same as even a very slight exhaust leak.
40inches
posted on 2/5/19 at 10:38 AM Reply With Quote
I had a problem getting the Lambda correct to the other readings, then discovered a small hole in the bike silencer, it
was the water drain hole at the lower back
