Author: Subject: How is the Brake Test Light Tested?
mark.silcock
posted on 7/5/19 at 10:45 AM Reply With Quote
How do they test the low fluid level light during the IVA?
mackei23b
posted on 7/5/19 at 11:17 AM Reply With Quote
I've taken a couple of cars through the IVA test, one of the testers took the reservoir cap of the master cylinder to check the level switch activated the warning lamp. I didn't notice how the tester did this on my last test.
James
posted on 7/5/19 at 11:53 AM Reply With Quote
My brake fluid reservoir has a push button on the top.
They just pushed that on my SVA test.
View User's Profile View All Posts By User U2U Member   James 's Aim
zx12r dug
posted on 7/5/19 at 12:03 PM Reply With Quote
Sure it's ignition on and handbrake off then test the cap if it's not got a button on then I guess they'll unscrew it and turn it upside down
mark.silcock
posted on 7/5/19 at 12:24 PM Reply With Quote
Thanks, and how should this work with twin reservoirs, either reservoir can activate the switch?
I have a feeling the previous owner hasn't wired it up correctly and both reservoirs need to be pressed or low at the same time for the light to come on.
mackei23b
posted on 7/5/19 at 04:30 PM Reply With Quote
Yes, I'd go for either cylinder to light up the warning
mark.silcock
posted on 8/5/19 at 01:42 PM Reply With Quote
Thanks,
Has anyone got a basic wire diagram?
CosKev3
posted on 9/5/19 at 02:33 PM Reply With Quote
It's simple wiring,the bulb has an ignition live to the positive side, then any switches you have go in the earth circuit.
