Author: Subject: Water Pump
Hitchen92
posted on 2/7/19 at 08:28 PM Reply With Quote
Water Pump
Hi All,
I've got a Westfield Megablade with a 919cc fireblade engine...
Trying to fit an electric water pump to the car after the prop came off and smashed the old water pump off...
The hole is blanked and just wondering if anybody can tell me how we would connect the new electric water pump as this only has 1 inlet and one outlet as opposed to the old mechanical one which has 4 (2 bigger ones and 2 smaller ones presumably for the oil cooler and top thermostat housing).
Any help is greatly appreciated.
Kris
R1MINI
posted on 4/7/19 at 05:45 PM Reply With Quote
So does the old water pump cycle water round your oil cooler? I'm doing an electric water pump for a suzuki hayabusa mini. That had a mechanical water pump before. all I'm going to do it remove the mechanical water pump and fit the electric water pump inline with my system, then use a Davis Craig flow controller to manage it it correctly. What electric water pump are you using? Can you upload any pictures?
Jay
