Author: Subject: AutoSparks DELUXE FRONT ENGINE KIT CAR WIRING HARNESS
nero1701
posted on 7/7/19 at 12:20 PM Reply With Quote
New in box, forgotten about and found up loft!!
Looking for 180 Plus Postage
I can also throw in the complete engine loom, ECU, Clocks, ect ect from an ST170, with the above price
Un-Used, Un-terminated.
Ready to use, Blurb from sales page:
The deluxe kit has additional features to the standard kit that are designed to improve the experience required for your vehicle, it adds increased fusing common in modern production vehicles, all lighting circuits are fused separately, the cooling fan is fused and there is an addition of an accessory socket for the use of Satnav and/or mobile phone charging. Pre-assembled in modern automotive thinwall cable with two 6-way fuse boxes and the required relays (with bases) to support the looms functionality.
The Front engine kit
Specific features: -
Sidelight circuits separately fused
Headlight circuits separately fused
Headlights via Relays
Fused Radiator Fan via a Relay (Ignition Switched Thermostatically Controlled)
Two-Speed Windscreen Wipers with Washer
Two-Speed Heater
Electric Fuel Pump
Ignition Switched 12-volt Accessory Socket
2nd Rear Fog Light Supply to meet competition requirements
All Earth wiring included
nero1701
posted on 21/7/19 at 02:53 PM Reply With Quote
Bump
