Author: Subject: Sierra column to escort rack
Nick
posted on 29/7/19 at 08:56 PM Reply With Quote
Evening chaps,
What bits do I need to get from my Sierra column to my escort rack please. Got in a muddle with what I need.
posted on 30/7/19 at 06:59 AM Reply With Quote
Sierra column, lower column with Flexi disc will work, you will probable need to cut and lengthen to suit. Alternatively you can use a splined shaft with a triangular coupling to fit the upper column and a UJ to fit the Escort rack , ageing the length can be altered to suit . Rally design and Car builders solutions sell the parts . Also be aware that the Sierra lower column was available in at least 3 different varieties of shaft diameter which may cause clearance problems. Have a look on here for info on using a self aligning bearing instead of the Sierra bulkhead bush.
Nick
posted on 30/7/19 at 09:12 AM Reply With Quote
Cheers buddy. The self aligning bearing is one bit I'm struggling in finding info about.
big_wasa
posted on 30/7/19 at 07:13 PM Reply With Quote
The bearing is easy enough.
Your steering column pokes through the bulkhead. Itís supported by a two piece plastic bush inside a rubber one. To aid self centring by reducing friction you ditch the outer plastic bush and the rubber bush. You keep the inner one that fits on the triangle and fit it into a self aligning 25mm bearing and bolt it to the bulkhead.
Itís then a case of cutting and sleeving the Sierra bits.
On the to do list is replacing the 30 year old rubber coupling on mine with a nice uj but itís a £100 touch plus work.
Nick
posted on 30/7/19 at 07:26 PM Reply With Quote
That's brilliant thank you for your reply and pictures
posted on 30/7/19 at 07:37 PM Reply With Quote
SLFL25 from simply bearings
SJ
posted on 30/7/19 at 07:38 PM Reply With Quote
Does replacing the Sierra bits make much difference to self centering?
big_wasa
posted on 30/7/19 at 08:34 PM Reply With Quote
Not a lot, but when you only have half what it should be every little helps.
Iíve seen some of the plastic bushes with deep grooves worn in to them
Nick
posted on 16/8/19 at 07:47 PM Reply With Quote
Sorted chaps. Thanks for the help.
Can't insert pic. 😀]
falcor75
posted on 25/8/19 at 07:58 AM Reply With Quote
I have sortof the same question but I'd like to know if there is any place I can buy a custom length splined shaft that fits the escort steering gear?
The longest I've found is 600 mm and I need 625 mm. Cutting and welding is not really an option for me.
Schrodinger
posted on 25/8/19 at 08:15 AM Reply With Quote
Have you made sure that the triangular section on the sierra column is out to it's full extension?
Keith
posted on 25/8/19 at 12:25 PM Reply With Quote
CPSDrivelink? They may be able to help
falcor75
posted on 25/8/19 at 03:19 PM Reply With Quote
I have about 16 cm of the triangular piece sticking out of the column. Seems pretty rigid in place.
