Author: Subject: Cosworth rear hubs
starterman
posted on 18/9/19 at 08:02 PM Reply With Quote
Cosworth rear hubs
As per the title I'm after a pair of cosworth rear hubs.
Mike
flanders
posted on 19/9/19 at 10:44 AM Reply With Quote
I have a pair of sierra disc brake hubs 50 plus post
posted on 19/9/19 at 02:12 PM Reply With Quote
Is there something different between normal disc brake rear hubs and Cosworth rear hubs?
djtom
posted on 19/9/19 at 03:16 PM Reply With Quote
Cosworth ones have extended "ears" for the brake caliper mount - this facilitates the fitting of the larger discs used on the cosworths I believe.
posted on 19/9/19 at 03:37 PM Reply With Quote
OK - makes sense - more power needs better brakes!
Given the low weight of a 7 type car do you need Cosworth brakes on the back?
I used drums on my MK Indy and never had any issues. I wasn't racing or hill climbing just road driving.
T66
posted on 19/9/19 at 04:53 PM Reply With Quote
Most of the brakes we use here, are for cars much heavier than our kit cars, ie Ford based discs/drums from Capri/Escort/Sierra.
starterman
posted on 19/9/19 at 05:41 PM Reply With Quote
Iam changing to a 7.5" LSD from a cosworth. I've bought new driveshafts and CV joints but the hub from the standard push in shfts doesn't fit. The splines are too small and the bearing carrier doesn't fit. Hence the need for cosworth hubs etc.
Mike
[Edited on 19/9/19 by starterman]
starterman
posted on 19/9/19 at 05:42 PM Reply With Quote
It's not about the brakes, it's just about being able to use the LSD.
