Author: Subject: FS: Ginetta G27
AntonUK
posted on 6/10/19 at 09:39 AM Reply With Quote
FS: Ginetta G27
For Sale - Ginetta G27
The time has come to part ways with my very much loved Ginetta G27. It was a factory built car in 1996 and is now a very rare car. Typically only 1 or 2 come up for sale each year.
Mileage is 4100, MOY until 29 June 2020. Car is fully road legal. Insurance is £130 for me (limited to 3000 miles, garaged, 10 year ncb, 36 years old)
Im owner number 4 and have owned it since 2014. I was told it was originally owned by a semi famous racing driver, but I can’t remember their name. I have some video footage from back in the late 90’s which features the car It also includes 5th gear’s very own Vikki Butler Henderson in the same race.
The car was in a garage in Cockermouth floods (freshwater) in 2009, where the owner at the time only used the car for the occasion sprint. He attempted to tidy it up and get the car started afterwards but failed. This is where I came in 2014 to buy as a project. At the time I thought it would be an easy quick turnaround with a new engine and maybe some wiring. This is where I went a little overboard and spend the next 5 years carrying out a full rebuild where everything was removed, cleaned, refurbed. The only thing that didn't come off was the main tub from the chassis.
I spent nearly 5 years rebuilding to what I believe is a unique and well spec’ed car. Since then I have used the car for various local shows, and the occasional trackday.
Since getting it finished, I’ve continued with the upgrades and tinkering. Just this year saw its conversion from the old clunky type 9 box to a smooth 6 speed mazda box, which also meant new flywheel, clutch, prop shaft, adaptor plate and starter motor.
Reason for sale, I really enjoyed rebuilding it and had some awesome fun driving it but I have had my time with it and it's time for a change. I have my eye on a GP1 mini too.
As with any car like this, its a raw experience on the road with plenty of power, no traction control or ABS. But get to drive it properly and it comes alive as an awesome piece of equipment
Location is Staffordshire UK, Can of course send further photos and info if needed. Inspection and test drives welcome. Please remember test drives will only be carried out with full insurance cover in place etc.
Bodywork
Good condition. Originally yellow gelcoat but resprayed by previous owner in red. Its no where near concours but good a fiberglass bodied car. Best colour match I found was ‘Mazda True Red’
Vinyl White Circles on doors
Caterham side mirrors
Engine
1.8 Silvertop Zetec
ARP rod bolts
Cams: Autosprint (Birmingham) IN - AS46 EX AS 92 Hydraulic, 110deg start point Zetec - Carburettor Performance Profiles - Hydraulic - 278° 278 Inlet 276 Exhaust
ST170 inlet, mated to GSXR 750 throttle bodies with PIPERCROSS PX600 filter
Lightweight 3.6kg steel flywheel with standard pinto clutch (cable operated) ARP flywheel bolts
Ported zetec head
Land Rover - ESR3926 in tank Fuel Pump with return
Exhaust manifold is a wrapped ginetta item leading to a repackable steel silencer by cherrybomb (2.25inch) - Tests at about 101dB
Raceline aluminium sump
Raceline aluminium water rail with Ford Escort 1.8 Zetec 1992-1999 Thermostat
Radiator: Nissens Radiator 651741 VW PASSAT (88-) 1.6 i
Megasquirt: MS2 on v3.0 board. running MS extra code. Direct driven wasted spark coil pack
Originally Rolling Roadtuned by Dale at Bailey Motorsport @150bhp but this was before the modded head and cams. Expected to be around 180bhp
Burton Power lightweight 40a alternator
Proper escort water pump to remove the need for an idler pulley
Nearly all Silicon hoses
Aluminum catch tank
New Pinto Starter motor
Remote oil filter setup
Running Gear
Mazda RX8 6 speed manual gearbox with adaptor
Ginetta modified Ford English live axle using 5 linkage setup
3jdriveline 22T 660mm uprated half shafts
Differential: 45/45 ramp angles make of LSD unknown - Large Flange English - rebuilt this year
LSD Oil: Castrol B373 Limited Slip Differential Gear Oil
Final Drive Ratio : 3.54:1
Custom propshaft
Luk Clutch Kit
Steering
Hybrid Sierra steering column with Vauxhall Agila / Suzuki Wagon R power steering. Dash adjustable assistance
Steering Column Bearing Ford Sierra P100 Scorpio Fiesta Granada Upper Steering
Quick Release steering wheel boss
Momo Steering Wheel MOMO MOD.78 STEERING WHEEL 6x70mm PCD
Suspension
New Front Coil Overs "Protech Shocks 600 Series Single Adjustable Bearing 2.25id
(Open Length: 12.0 inch / 305mm, Top Eye, Bush Width and Hole Diameter (Top Hat): New Rear Coil Overs "Protech Shocks 600 Series Single Adjustable Bearing 2.25id
(Open Length: 15.5 inch / 394mm, Top Eye, Bush Width and Hole Diameter (Top Hat):
Front Springs 2.25inch 250lb
Rear Springs 2.25inch 145lb
Bottom Ball Joints Saab 900
Adjustable (camber) top wishbones with rose joint at upright end- poly bushed at chassis side
Rear suspension - 5 link setup all rose jointed (except one end of the panhard - TVR Shock Absorber Bush - C0092)
Wheels & Tyres
Rare Compomotive FH 15x7 wheels wrapped in nearly new AD08R 195/50r15’s PCD 4x108mm Painted grey
Interior
Re-built dash with updated layout and switches
Digidash: 20x4 LCD with Arduino and Seeedstudio CANbus shield
Original (but tatty) seats included
New high back narrow bucket seats from JK Composites
6 point FIA harnesses (in date)
Brakes
Split system bias adjustable pedal box, Wilwood master cylinders
Front Calipers - Wilwood 4pot Midilite Caliper with braided hoses
Rear Calipers - Standard escort with braided hoses
Front Pads Wilwood: EBC Greenstuff (for Midilite Caliper)
Rear Pads MINTEX REAR BRAKE PAD SET FORD SIERRA 1987-1993 MDB1287
Black coated braided hoses at all 4 corners
Safety
Fire Extinguisher: Lifeline with nozzles in engine bay and drivers lap. Bottle had timed out, and will need replacement if using for competitive events
Full roll cage. I only have the rear section installed but I have the front sections and drivers door bar which will come with the car.
Included
Spare set of front wishbones
Original Ginetta build manual
Sierra, Escort and Mondeo Haynes Manuals
CD containing 90’s video footage and ECU maps/software
Poor Points
The MX5 headlight pop up motors have gotten stiff and won't pop successfully. But I never use the car in the dark so it doesn't cause an issue
Some minor gelcoat cracking in places
I'm an 84kg, 6’ tall, 34” waist guy. I can drive it quite comfortably although depending on your build, you may want to either replace or reposition the seats.
£12000
[Edited on 6/10/19 by AntonUK]
Build Photos Here
AntonUK
posted on 6/10/19 at 09:44 AM Reply With Quote
More photos in my archive
Build Photos Here
computid
posted on 6/10/19 at 05:05 PM Reply With Quote
Just an observation, you haven't stated a price!
Lovely car though!
Bikes: Yamaha XT660Z Tenere, Tuned Yamaha YZF-R1, in-build Turbo 2004 YZF-R1
Cars: A Minari RSR (Road Sport Racing) 1.7 16V Fuel Injected racer, a BMW E30 325i, a BMW E36 325i Coupe, a BMW E36 328i Vert, 2004 Vauxhall Astra H 1.8 SRI, 2010 Mazda 6 Sport 2.2TD, 2011 Range Rover Vogue 4.4 TDV8
AntonUK
posted on 6/10/19 at 05:18 PM Reply With Quote
thanks now added
Build Photos Here
AntonUK
posted on 2/9/20 at 08:17 PM Reply With Quote
Now people are starting spend some of money, I'm bumping this to the top again.
Build Photos Here
