Author: Subject: Which clutch cable
Nick
posted on 8/10/19 at 06:46 PM Reply With Quote
Which clutch cable
Clutch cable advice this time. What cable do people use with locost pedal box and type 9 5 speed. I'm sure Sierra used a self adjusting pedal so no need for an adjuster on the cable. As I'm not using Sierra pedal I need a cable with an adjuster.
Any ideas please.
big_wasa
posted on 8/10/19 at 08:10 PM Reply With Quote
I used a cortina cable for my last one and ive just ordered another for this one.
Escort is very short
Cortina is bit longer
Capri is a bit longer still
posted on 8/10/19 at 08:35 PM Reply With Quote
I used a mk2 Escort cable with a locost pedal box and type 9 but use an angled conduit against the bulkhead to get a decent routing for the cable which has a P clip securing it to the engine mounting bracket. Check the Burtonpower website ,shows clutch cable length which may help?
Nick
posted on 8/10/19 at 08:55 PM Reply With Quote
Awesome. I had looked on Burton. But wasn't sure. Will get one ordered. Cheers people
voucht
posted on 9/10/19 at 07:44 AM Reply With Quote
I used a Ford Capri clutch cable because it also has a 6mm diameter "eye" end, and is easy to attach to the clutch pedal with a 6mm bolt.
[Edited on 9/10/19 by voucht]
Sylvain
http://vouchtroadster.blogspot.se/
SJ
posted on 9/10/19 at 08:14 AM Reply With Quote
Capri for me as well.
posted on 9/10/19 at 09:31 AM Reply With Quote
If using a bolt at the pedal end make sure it is not over tightened as it will cause the cable to fracture
voucht
posted on 9/10/19 at 09:43 AM Reply With Quote
Of course. Mine is moving freely around an axle made by the slick part of the 6mm bolt.
Sylvain
posted on 9/10/19 at 11:06 AM Reply With Quote
IIRC I used a Capri clutch cable on my MK Indy. MK supplied chasis and pedals with a Pinto and T9 gear box. Worked fine for me.
