Author: Subject: Plastic fuel tank leak - Daytona 955i
Simon
posted on 19/1/20 at 10:01 PM Reply With Quote
The o/s side panel was held on by cable ties and thought it might be a nice idea to fix it properly. So, tried removing the bodge fix; turns out this is straight into petrol tank which started leaking.
Anyway, I'm in the process of emptying tank then will drill out bodge and make a metal helicoil that I will "glue" into place.
So, the question is - what glue?
S
Mark RSP
posted on 19/1/20 at 10:21 PM Reply With Quote
Years ago I used to use Araldite epoxy resin but I bet there are purpose adhesives out there now for the job
steve m
posted on 20/1/20 at 08:43 AM Reply With Quote
I also used Araldite, on a rusty Norton tank, but if I was to do it again, I would also after the araldite was cured
line the tank with a tank sealer, most good bike shop's sell the stuff
steve
Simon
posted on 20/1/20 at 10:08 AM Reply With Quote
Cheers chaps
r1_pete
posted on 20/1/20 at 10:20 AM Reply With Quote
I think I’d be on the look out for a replacement tank. The original holes are probably blind, and in use the tank will flex slightly but probably enough to crack a repair.
Its your bike but I wouldn’t risk a leaky tank, if it does drip its onto a hot engine, and will no doubt soak into your trousers.
