Author: Subject: Which Kubota Alternator??
J90rdn
posted on 28/5/20 at 10:45 PM Reply With Quote
Looking for a lightweight Denso/Kubota alternator. Not much second hand on eBay atm, so looking like it might need to be new. It's going on a Zetec blacktop, and I already have an old style Raceline alternator bracket like this
I've noticed 2 on eBay from the sale seller. 1 is a 2 pin and 1 is a 3 pin. Can someone please confirm they are the correct type alternators, whether they will fit the bracket I have, and if I need a 2 or 3 pin (I'm hopeless with electrics)?
3 pin for £80 delivered
https://www.ebay.co.uk/itm/Denso-Kubota-kit-car-race-car-light-weight-new-3-pin-40-amp-Alternator-2-8KG/114239669696?epid=1052142108&hash=item1a99 3705c0:g:htAAAOSwq3hexoY2
2 pin for £85 delivered
https://www.ebay.co.uk/itm/Denso-Kubota-kit-car-race-car-light-weight-new-2-pin-40-amp-Alternator-2-8KG/114231984511?epid=1052142108&hash=item1a98 c1c17f:g:lO0AAOSwvjVex4Sj
TIA
J666AYP
posted on 29/5/20 at 02:14 AM Reply With Quote
Starterman on here is probably the best choise for sourcing what you need. He was very helpful with mine.
J
Shooter63
posted on 29/5/20 at 05:32 AM Reply With Quote
I second starterman, it will come with the correct ribbed pulley etc on my silvertop i just needed to space it out a bit to line up with the bottom pulley, but my bracket is different, so yours may fit straight on
Shooter
starterman
posted on 29/5/20 at 07:12 AM Reply With Quote
£72 all in with a ribbed pulley.
wonderfulweasel
Yep, starterman was very helpful in supplying mine.
J90rdn
posted on 29/5/20 at 09:44 AM Reply With Quote
Hi. Can you provide or PM me details please? Will it be the 2 or 3 pin model, which make and model, weight, and will it fit that alternator bracket. Many thanks
starterman
posted on 29/5/20 at 06:31 PM Reply With Quote
If you want to measure the distance between the lugs on your bracket I'm sure I can find you an alternative if you want.
You can have 2 or 3 pin and I have no idea if it will fit that bracket. I've no idea what size the bracket is. It will be a Denso copy unit as they all are. No idea how much it weighs, because there is nothing smaller or lighter so weight doesn't really matter.
[Edited on 29/5/20 by starterman]
J90rdn
posted on 29/5/20 at 06:37 PM Reply With Quote
Whats the difference between the 2 and 3 pin?
starterman
posted on 29/5/20 at 06:45 PM Reply With Quote
The 2 pin is ignition and light feed
The 3 pin comes in Dummy, Ignition and light or Sense, Ignition and light, or com, ignition and light or Phase, ignition and light.
The choice is yours but choose the 2 pin, its easier to wire.
J90rdn
posted on 29/5/20 at 06:56 PM Reply With Quote
OK thanks - 2 pin it is, I need it as easy as possible.
If you U2U me payment details I'll get the money across to you.
starterman
posted on 29/5/20 at 07:04 PM Reply With Quote
U2U me your address and email address and I'll send an invoice. Obviously I won't be able to send the unit until Monday, but I will send it by TNT.
What pulley would you like fitted?
J90rdn
posted on 29/5/20 at 07:10 PM Reply With Quote
Done. The ribbed pulley please, to match the Zetec crank pulley.
starterman
posted on 29/5/20 at 07:13 PM Reply With Quote
Consider it done
