Author: Subject: Engine oil choices
tegwin
posted on 15/6/20 at 07:24 AM Reply With Quote
Engine oil choices
I have a 20 year old polo GTI... Still drive it spiritedly... on 160,000 miles.
Had it for 15 years...
I have always used Castrol Edge 10W40 oil but this time around the halfords & Castrol websites both say to use 5W30, 5W40 or 0W40
I still have a 4 litre bottle of 10W40 but am curious why there has been a change and what difference the alternative grades of oil would actually make?
www.verticalhorizonsmedia.tv
pmc_3
posted on 15/6/20 at 08:05 AM Reply With Quote
Because of the mileage i'd stick with the 10/40
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
CosKev3
posted on 15/6/20 at 09:13 AM Reply With Quote
The first number is how thick the oil is cold,so 5 is thinner than 10.
So 5 offers better protection starting the engine cold as it gets around faster.
I would stick to what you've been using tbh.
posted on 15/6/20 at 09:14 AM Reply With Quote
I suspect oil consumption may rise using the later spec oil , think I would stick with what you have been using
Mr Whippy
posted on 15/6/20 at 09:22 AM Reply With Quote
I'd use what it says in the cars handbook over any website, I'd also stick with 10W/40 and the same brand
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
posted on 15/6/20 at 11:42 AM Reply With Quote
I'd stick with what VW say in the handbook myself.
On a 160,000 mile engine the tolerances will have opened up a bit so 10W/40 seems reasonable. From what I've seen it's the newer car engines that ask for 5W/xx oils (often 5W/30), probably because they're made to tighter tolerances when new.
posted on 15/6/20 at 12:30 PM Reply With Quote
Use what you have but there is lot of mis-information surounding oils, on an engine in good health most oil consumption is due to vapour boiling off.
Fully synthetic oils boil off very little vapour so a 5w-40 fully syntetic will give lower oil consumption than a 10w-40 semi-or 15w-40 mineral
In reality any fully synthetic oil is not fully synthetic it will contain small ammounts of mineral oil as an additive to condition the oil seals, and oils sold as mineral oil contain at least some synthetic as an additive to improve the viscosity index and the detergent qualities.
Semi-synthetic is actually vague term it really means not much.
Lately I have been using this product it is very high quality -- even the container is good quality and great vfm
MANNOL 5L Fully Synthetic Engine Oil EXTREME 5W-40 SN/CH-4 ACEA A3/B4 VW 502/505
[Edited on 15/6/20 by britishtrident]
[I] What use our work, Bennet, if we cannot care for those we love? .
tegwin
posted on 15/6/20 at 12:33 PM Reply With Quote
Thanks for all the replies. Sounds fairly unanimous. I will get the same stuff Ive always used.
Heavy oil consumption isnt an issue at the moment thankfully. My biggest issue is body corrosion 😳🙀
posted on 15/6/20 at 02:41 PM Reply With Quote
I'd say corrosion's to be expected on a 20 year old steel car, once it's taken hold there's little you can do to stop it.
posted on 15/6/20 at 04:20 PM Reply With Quote
Project Farm YouTube channel did a whole list of videos doing rough and ready tests on US oil brands ---
Well worth watching https://www.youtube.com/playlist?list=PLjT3B9r2z3fXlvbP3tb9e056Q8O5krrCW
For anybody not owning a engine with particularly specialised lubrication requirements (which many modern PD, GDI and VVT engines have) then it shows with synthetic oils the cheapersupermarket oils are a really good buy.
For older vehicles I personally look for oils the meet BMW Longlife-04 spec.
