Author: Subject: T5 gearbox oil
r1_pete
posted on 21/6/20 at 12:26 PM Reply With Quote
T5 gearbox oil
I've a fully rebuilt Tremec (BW) T5 gearbox ready to go into my car.
It seems Dextron 2 ATF is the recommended Oil, I'm just wondering if there is anything better? Its a late 80s design and oil tech has moved on in that time.
Cheers.
posted on 21/6/20 at 01:31 PM Reply With Quote
I would use MTF-94 --- it was developed for Land-Rover and Rover and used for Honda it solved a a lot of issues Land-Rover were having on Defender and Range Rover 5 speed manual boxes replacing the Dexron 2 theys had used as an interim solution.
mcerd1
posted on 22/6/20 at 03:11 PM Reply With Quote
Tremec themselves still say Dexron II
https://www.tremec.com/anexos/TRSM-T5-0510-R1_173.pdf
APPROVED LUBRICANT.
Most T5 transmission models use Dexron II automatic transmission fluid.
Refer the vehicle owner’s manual or service manual for lubricant specifications.
but the T5 is a bit different from the LT77 / R380 boxes, I've alway seen Dexron II as the recommendation for T5's in cossie's or in TVR's
[Edited on 22/6/2020 by mcerd1]
