Author: Subject: FOR SALE LOADS OF XFLOW BITS
CallumBarnes
posted on 25/6/20 at 07:39 PM Reply With Quote
I am converting my Locost to a MA7DA platform and I have lots of high quality crossflow bits for sale.
all parts are of premium quality and have been well maintained.
Please call me on 07552711388.
Locost Xflow 4 into 1 exhaust manifold £110.00
Dual Weber DCOE 40 carbs with Xflow M4240A 4.25" inlet manifold and pipercross air filter and throttle linkage kit £600.00
Xflow 1300 Crankshaft, Mains 10 Thou, Big Ends 40 Thou £150.00
Petrol King Fuel Saver Regulator £25.00
Spark plug leads red £10.00
Spark plug leads black £10.00
Xflow Altenator £20.00
1300 Xflow Block +20 bore including pistons £350.00
1300 Xflow Block +40 bore including pistons £350.00
Xflow 1300 head standard full refurbished £200.00
Xflow 1300 /1600 head full race ported £300.00
Xflow 1300 / 1600 Standrd rockershaft assembly £20.00
Xflow 1300 / 1600 steel posted rocker shaft Assembly £100.00
Kent 285 Performance CAM £100.00
Kent P103-4 750MC Locost Regulation Camshaft £60.00
Xflow 1300 / 1600 Timing chain cover £15.00
Type 2 standard 4 speed gearbox £80.00
Locost Propshaft from Type 2 gearbox to english axle £50.00
Xflow 1300 / 1600 Alloy Rocker cover £60.00
Xflow 1300 / 1600 Standard rocker cover £15.00
Xflow 1300 / 1600 oil Pickup Pipe £10.00
Xflow 1300 / 1600 Dipstick £10.00
Xflow 1300 Sump £30.00
Xflow Starter Motor £20.00
Xflow Burton Power High Pressure Oil Pump £25.00
MK2 escort Standard Radiator £20.00
Ford English Axle diff 4.125:1 £200.00
[Edited on 25/6/2020 by CallumBarnes]
Callum
posted on 25/6/20 at 08:22 PM Reply With Quote
Just to point out a 1300 sump isnít the same as a 1600 , using a 1300 sump will cause clearance issues on a 1600
trextr7monkey
posted on 26/6/20 at 01:07 PM Reply With Quote
Any pics of alloy rocket cover? You can load them into your personal photos folder on here which is much easier than getting them loaded onto the forum. If it is any good I could probably collect
Atb
Mike
MikeR
posted on 26/6/20 at 08:35 PM Reply With Quote
Could you share details on the race head. Who did the work, valve size, what is / isn't included etc
Could also be interested in the pick up pipe.
steve m
posted on 26/6/20 at 08:40 PM Reply With Quote
How do you only have one post, but sell ??
I binned 50% of my crossflow stuff, as it was all on ebay and didn't sell
steve
MikeR
posted on 27/6/20 at 08:58 AM Reply With Quote
Wish I knew parts were going in the bin. I'm a serial xflow parts collector
adithorp
posted on 27/6/20 at 03:05 PM Reply With Quote
Any pictures of the 4into1 manifold?
http://jpsc.org.uk/forum/
