PumaWestie
| posted on 20/7/20 at 08:10 AM |
Lightweight Nippon Desno alternator
As new small Nippon Denso alternator.
Fitted with 63mm multi grooved pulley
With wiring plug and connector
£75 posted
John
O797I 576848
| posted on 20/7/20 at 01:56 PM |
GLWTS
I used the same alternator in my MK Indy and it worked faultlessly, nice and compact as well so fitted in the chasis space very well.
RWD Focus
| posted on 20/7/20 at 04:53 PM |
Hi what amp output is this please
Thank you
PumaWestie
| posted on 20/7/20 at 05:02 PM |
45A I believe
PumaWestie
| posted on 20/7/20 at 05:37 PM |
Actually I think 40A
[Edited on 20/7/20 by PumaWestie]
starterman
| posted on 20/7/20 at 06:08 PM |
Thank you
40 Amp
Angel Acevedo
| posted on 6/8/20 at 03:34 AM |
£75 posted
John
O797I 576848
Sorry for the thread hijack.
I am trying to shoehorn a V8 into my chassis.
Do you have a part number for this.
Feel free to send via U2U.
I would take a shot but shipping will be a killer to Mexico.
Thanks in advance and best regards:
Angel Acevedo
Angel Acevedo
| posted on 6/8/20 at 03:41 AM |
1st Dibs if sensible money for shipping to Mexico. Post Code 24157.
CosKev3
| posted on 6/8/20 at 05:46 AM |
Not to try and spoil your for sale thread but anyone with a V6 or V8 check your required amps at idle before fitting these little Densos,they only
make circa 30amps at idle.
I'm struggling on my V6 with a EWP and high power rad fan at idle.
starterman
| posted on 6/8/20 at 06:57 AM |
Fit the bigger amperage version
CosKev3
| posted on 6/8/20 at 06:59 AM |
In the same size casing as these?
starterman
| posted on 6/8/20 at 07:03 AM |
Yes, When I've got my day up and sorted here then I will find you a part number etc.
Mike
starterman
| posted on 6/8/20 at 07:12 AM |
There are 3 different sizes of small Denso type alternator. This is measured between the mounting holes. They are 138mm, 148mm and 153mm.
The 60 amp unit comes in the 153mm size and are normally fitted on a John Deere. Electrical connection wise they are an ignition and light feed in a T
plug. Price wise you should be looking at something like £89 all in including a pulley. Unless the pulley is something out of the ordinary.
OE Part Number would be 101211-2470
Mike
CosKev3
| posted on 6/8/20 at 07:15 AM |
Mike
Thanks.
Any info on idle output amps available on the biggest one?
starterman
| posted on 6/8/20 at 07:25 AM |
I can put one on test later and see what it comes up with.
CosKev3
| posted on 6/8/20 at 07:28 AM |
Ok thanks
PumaWestie
| posted on 6/8/20 at 09:58 AM |
Back on topic - still fr sale despite the hijack.
This is as new and has a larger pulley fitted to keep it below the recommended rpm and has the electrical connector
Al3xG
| posted on 6/8/20 at 10:34 AM |
Is the pulley a 5 grooves one? Any chance I can have it alone?
PumaWestie
| posted on 6/8/20 at 11:47 AM |
Hi sorry but I'm not willing to split it up
starterman
| posted on 6/8/20 at 12:10 PM |
What's the recommended RPM?
Al3xG
| posted on 6/8/20 at 12:53 PM |
starterman I've just sent you a U2U as I don't want to hijack this thread. Thanks.
Angel Acevedo
| posted on 6/8/20 at 02:30 PM |
Still interested.
Let me know price including shipment.
I don´t want to vent how much it costs here...
PumaWestie
| posted on 8/8/20 at 08:01 AM |
Now sold
Now sold
