Author: Subject: Pinto transmission question
FastBarney
posted on 17/8/20 at 09:54 PM Reply With Quote
Hey Guys,
For my project i am looking for a other pinto engine.
I found a good engine but it has a automatique gearbox.
Kan use That engine in the type 9 that is in the car.
If i swap the clutch and flywheel?
theconrodkid
posted on 18/8/20 at 06:18 AM Reply With Quote
short answer is yes, you just need to put a spigot bearing in the back of the crank
other things like starter, carb, dizzy and cam may be different but thats no biggy.
[Edited on 18/8/20 by theconrodkid]
who cares who wins
pass the pork pies
posted on 18/8/20 at 06:32 AM Reply With Quote
As Conroe says . I have in the past changed engines ( not Pinto I must say) from auto to manual, sometimes there is a bush you have to remove in order to fit the spigot bush
