Author: Subject: Standard ecu & battery feed
FFMan
posted on 23/9/20 at 06:51 PM Reply With Quote
I'm building a track car, currently using the standard ecu. I note it has a permanent battery feed but i want to fit an isolator that cuts all battery connections.
Does the ecu need the perm feed to retain trim values or will it not mind if i wire that to a feed that goes dead ?
gremlin1234
posted on 23/9/20 at 07:33 PM Reply With Quote
many/most oem ecu will 'forget' the learned parameters if disconnected for more than a few minutes. you could give it a 'permanent live' though a very small fuse (say 50 or 100mA) (or perhaps a pp3 battery!)
but another key thing is to have a good chassis/ground to the ecu, and reference all sensors from that.
