Author: Subject: Wheels... Offsets... Sizes....
toolate
posted on 6/10/20 at 11:56 AM Reply With Quote
Hi all.
I have myself a Westfield with a set of 13" alloys with all 7" wide. The rears are running with 25mm spacers on.
I am looking to get myself a set of CXR alloys but i am unclear whether is should be getting then 7" wide all around or have the rears in 8"
Also, how do i work out which ET i should be getting or looking at?
TooLate
MikeR
posted on 6/10/20 at 02:20 PM Reply With Quote
nice site explain ET and how to calculate.
https://www.oponeo.co.uk/blog/wheel-width-and-et-offset-explained
Regarding your current question, you need to know the current wheel ET, then 'add' 25mm for the spacers. At that point you need to look at where the wheel is. How much space do you have at the rear (towards the middle of the car) and how much at the front (towards the pavement). You then can juggle the ET to fit the biggest wheel you want to. Although please check clearence when the wheel is going over a bump and the suspension is compressed. ie it doesn't rub inside the wheel arch.
toolate
posted on 6/10/20 at 02:25 PM Reply With Quote
Thanks MikeR!
CosKev3
posted on 6/10/20 at 02:32 PM Reply With Quote
I use
www.willtheyfit.com
Excellent site that tells you difference in speedo reading etc and a diagram of how the wheels will sit in the arch
CosKev3
posted on 6/10/20 at 02:33 PM Reply With Quote
https://www.willtheyfit.com
steve m
posted on 6/10/20 at 05:30 PM Reply With Quote
I believe i used the will they fit site as well, as it does look familiar
Hand have to say, that when i ordered my wheels, they were EXCACTLY what i was after, so proves doing your homework makes the job easier
steve
