Author: Subject: Sierra rear hubs resistance
will121
posted on 18/3/21 at 09:05 PM Reply With Quote
How much resistance to turn should there be in a sierra rear bolt on hub?? Not fully torqued them up yet as on axle stands but already difficult to rotate by hand
posted on 18/3/21 at 09:26 PM Reply With Quote
They will be tight until run
jollygreengiant
posted on 19/3/21 at 01:18 AM Reply With Quote
Absolutely correct. 285Nm of tightness on the nut, normally one side Left hand thread, one side Right hand thread. Normally I would use a long (stiff/rigid metal) lever (ie a 3ft tyre lever) using two studs and the hub spigot as a reaction lever points, to torque against, so that you KNOW you are not moving the vehicle when torquing that tight.
