Author: Subject: Different Pinto clutch for EFi?
peter_m7uk
posted on 8/4/21 at 07:50 PM Reply With Quote
As my engine and gearbox are out at the moment, I've been looking for any other jobs to do. I decided to buy a new clutch kit, but I was faced with a choice of which engine type. Mine is N4A, as it's the 2.0 EFi, but the closest I was offered by the auto factor was N4B, which is the lower powered one with a catalyst.
Now I'm unsure whether the clutch I already had was the correct one anyway! And which one to buy now. Looking at my pic of the original donor clutch, which I binned, the central spring "fingers" are quite short, like the one here - https:// www.onlineautomotive.co.uk/car-parts/Ford/Sierra/2.0L/Petrol/National-Auto-Parts/Transmission/Clutch-Kits-and-Parts/CK9001/1/497. Also, I notice that one has 4 large springs in the friction disc. The pressure plate looks more like this "heavy duty" one - https://www.burtonpower.com/helix-hd-clutch-cover-ford-s ohc-pinto-2-0-215mm-60-2851.html
Whereas my current clutch is more like this - https://www.burtonpower.com/luk-std-clutch-kit-ford-2-0-s ohc-pinto-215mm-622017506.html - with longer "fingers" and 6 smaller springs in the friction disc.
I'm wondering, did I fit the wrong clutch?! 🤔 The non EFi engines only went up to 99hp, whereas my EFi has 114hp, so maybe it was supposed to have a heavier duty version??
[Edited on 8/4/21 by peter_m7uk]
jacko
posted on 8/4/21 at 08:06 PM Reply With Quote
I would go with the five spring clutch
Also pintos never had catalyst in the exhaust
mcerd1
posted on 8/4/21 at 08:09 PM Reply With Quote
^^ I wouldn't worry unless your trying to make silly power from the engine
it'll probably make more difference if you pic a good brand of clutch - my engine builder recommend the bog std LUK one (the ones the burtons sell) as thats what he used in his tuned competition pinto engines - he reckoned they were easily good enough for 180hp+ (and likely a lot more in a lightweight car that will spin the wheels first anyway)
folk have use the same clutches on more powerful zetec's and duratec's too
mcerd1
posted on 8/4/21 at 08:16 PM Reply With Quote
^^ in the UK at least
peter_m7uk
posted on 10/4/21 at 02:12 PM Reply With Quote
I collected an LUK clutch kit today, for the injection engine. It has the short spring "fingers" like the original and the Burton heavy duty one, so I'm very happy 😃😃
The original was Valeo and was probably fine! Only thing is I bought it 2nd hand from eBay years ago and I don't know the history (the release bearing was new). The reason the engine and gearbox are out is due to a clunking noise when I raise the clutch to bite point after everything has warmed up.. I've had the gearbox rebuilt, I'm changing the spigot bearing in the end of the crank, so I thought why not a brand new clutch and release bearing to be definitely on the safe side!
On the catalyst Pinto, mcerd1 is correct - The UK EFi Pinto (my engine) doesn't have a catalyst, but there was definitely one in production, in the United States, I believe.
