Author: Subject: Jeremy Philips fuse box location
John G
posted on 9/4/21 at 04:14 PM Reply With Quote
I have been helping my brother in law sort his factory built 1100cc kawasaki engined car for the MOT. There is no full beam on both sides so I suspect a fuse problem. Problem is that I can't locate the fuse box! Any pointers.
Regards, Jon
pigeondave
posted on 9/4/21 at 04:34 PM Reply With Quote
It'll be at the end of a big bundle of wires?
Which car is it?
I have a Fury and there's only about 8 fuses on an old escort loom. Its on the engine side of the bulkhead.
jacko
posted on 9/4/21 at 05:11 PM Reply With Quote
Could the problem be at the light stalk
adithorp
posted on 9/4/21 at 06:33 PM Reply With Quote
Might sound daft but have you checked the bulbs. I get folks in at work every week with "wiring faults" because they have no head/brake/side lights and they've dismissed it being multiple bulb failures only for it to be exactly that.
http://jpsc.org.uk/forum/
gremlin1234
posted on 9/4/21 at 07:05 PM Reply With Quote
as I remember it the escort used a lucas based loom, and certainly in the austin/triumph/etc version of this the 'flash' was wired separately. -
hence, do the lights work on 'flash'?
Mr Whippy
posted on 9/4/21 at 08:30 PM Reply With Quote
Sounds like the headlight relay. If it uses one you should hear it click or failing that the chances are the indicator relay is in the fuse box so just locate the clicking noise from that to find the fuse box.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
obfripper
posted on 10/4/21 at 12:13 PM Reply With Quote
If it was built from an escort based kit, it is quite likely to have a mini/bmc based wiring loom as it used mini column switches, wipers, and rocker switches and was the recommended approach.
They generally have one or two 4way fuseboxes for most things, and inline glass fuse holders for the sidelamps/hazards/flash.
On my striker you need your head in the footwell to see the fuses as they're behind the dash which isn't ideal, you may have a similar layout.
Be wary that a fuse that looks good can also be at fault, the caps on the glass fuses are sometimes plated, this can delaminate and break the circuit - i had to replace most of mine to stop random intermittent faults caused by this.
Here's a list of all the bmc wire colours and functions, it may help to trace any faults if the correct wire colours were used .
http://www.mgb-stuff.org.uk/colourcodes.htm
Dave
