Author: Subject: Wilwood master cylinder help
rdodger
posted on 28/4/21 at 03:50 PM Reply With Quote
Hi all
My Riot has a remote clutch master cylinder that I want to replace.
It uses 7/16" on inlet and outlet. I don't seem to be able to find a new one the same.
Then I noticed Wilwood and some others supply their MC's with an adapter in the outlet to make it 3/8"
So to my question. Is the Wilwood master cylinder 7/16" under that adapter?
Shooter63
posted on 29/4/21 at 07:38 AM Reply With Quote
I'm not sure if it helps but I've got Tiltons and the ports are 7/16unf which I'm pretty sure is industry standard
Shooter
rdodger
posted on 29/4/21 at 10:51 AM Reply With Quote
Just for info
It would seem that the Wilwood MC is 1/8" npt with an adapter to 3/8 on the outlet.
