Author: Subject: SSC Stlylus for sale
number-1
posted on 7/5/21 at 04:24 PM Reply With Quote
Up for sale is my SSC stylus. (Stylus sports cars) Its a very well sorted car but i dont get time to drive it and i need room in the garage so its up for sale.
The cockpit, like most kit cars isnt huge. Im 6'1, very broad shoulders and around 18 stone and its snug (48inch chest and 36 waist) so would suggest its suited to someone smaller.
Siltec own the rights to the car parts so spares are easy to get. The engine was from a 2L silvertop Mondeo and has only done around 12k in total.... 10k then the clocks were changed for white ETB ones fitted at the moment. I have the old clocks to prove this.
Rebuilt silvertop 2L Zetec engine (after removing form the Mondeo) with new main bearings, big end bearings and oil pump.
60a Denso alternator
Canems fuel injection mapable ECU
Custom made re packable exhaust made by Martin Keenan. Repacked in 2020
Bespoke 4 into 1 exhaust manifold wrapped in titanium heat wrap (2020)
Helix 4 paddle HD clutch
Raceline flywheel and sump
Oddessy PC680 gel battery (2020)
Gearbox is V6 type 9, rebuilt with all new bearings, HD layshaft bearings and HD syncro rings
Retro ford hydraulic clutch
Davis craig electric water pump and digital control
Retro ford water rail
Coolex triple core radiator
Mocol remote oil filter, thermostatic take off and oil cooler
Procomp suspension all around
Wilwood midilite calipers on 285mm vented dics
Rally design rear disc brake conversion on 240mm discs
English axle with rare 3.54 genuine Ford crown wheel and pinion set with Quaife ATB diff
Custom made 8.7 gallon (40L) fuel tank. This is perfect for long trips.
Facet silvertop low pressure fuel pump into swirl pot and sytec HD pump
Kawasaki ZX12r 46mm throttle bodies with flow tested and cleaned injectors (2020)
Pipercross air filter (2020)
Danst 100mm velocity stack kit (2020)
ETB cobra white face dash dials
LED headlights
Full weather gear.....that actually fits and keeps you dry!
OBP billit alloy pedals
Willwood master cylinders
New plugs, HT leads and coil pack (2020)
New oil and coolant and oil filter (2020)
Lightweight bucket seats
Freshly powder coated alloy wheels with road legal semi slick tyres fitted (2020)
Freshly powder coated cam cover (2020)
Fast road brake pads
Oil catch can
FIA kill switch
Removable steering wheel (2020)
A huge box of receipts, 2 keys, fresh 12 months MOT as of 30/04/21. The car sounds amazing, both inlet noise and exhaust.
£8000 ono. The car can be viewed in Aylesbury, Bucks
Pistonheads link
number-1
posted on 26/6/21 at 06:14 PM Reply With Quote
SOLD
The car is now sold!
