Author: Subject: P0443 Fault
the_big_1
posted on 25/5/21 at 05:03 PM Reply With Quote
P0443 Fault
Hi guys,
I have fault code P0443 which I think is the EVAP not connected.
On a blacktop ECU, (LAAN ECU) what pin is it?
Is it pin67 Evaporative Emissions (EVAP) canister vent?
Also listed on the diagram is Pin56 EVAP canister purge valve but no hole in plug. And Pin47 EVAP regulator solenoid but again, no hole in plug. So hoping it is pin 67 lol
Cheers!!!!
RichN
posted on 28/5/21 at 11:43 AM Reply With Quote
I am running a Zetec-SE and I have this code because I removed the EVAP as I was told to, and blocked up the pipes. The car runs fine without it.
