Author: Subject: 1992 NEW unused SE Narrow Live Axle Rolling Chassis & 4AGE engine - unbuilt new kit, entire project package for sale
Beggers
posted on 22/6/21 at 05:15 PM Reply With Quote
1992 Narrow SE unbuilt kit. Never been used, raced or on the road in any form.
Asking £4,000 for entire complete project there is a lot of stuff, I've tried to list below everything. Or £3,000 without engine and custom bellhousing. I've spent nearer £6k as is the way with some projects.
I got this last year after a friend found it as a project barn find from an estate sale. Due to other commitments I'm unlikely to be able to finish so realistic option is sell. Giving it priority on here for couple of weeks.
No plans to split, the whole package goes as a lot. There is a lot of stuff, so needs trailer or van and maybe a couple of runs? Fills most of my shed now (see last pic) plus the chassis! Happy to work with a forum member on handing over knowledge of project and 4AGE installs. Also if needed I can strip more parts off to get chassis transportable in back of a large van or have it rolling on wheels ready for a trailer etc with body clamped down.
What you get:-
All Westfield tags and paperwork/invoices of sale from 1992, all matching numbers tags on chassis.
Huge folder of receipts from 92 until now.
Unbuilt Narrow live axle chassis painted black with all wishbones recently powder coasted black. Suspension and axle assembled along with fuel/brake lines and the ali panels sikaflexed and riveted on. New bushes used and new bolts, new ball joints etc.
Full set of body work including boot box cycle wings -used.
4AGE engine removed from running driving Mk1 MR2 with donor car v5 in my name(to be passed on) and vin plates ready for proof of engine age at IVA - all matched for IVA reg as 1987 emissions standard. Plan was put this on F plate or Q plate. 4AGE flyhweel and pinto AP racing clutch and Spigot bearing ready for type 9. Engine is ready to drop in with custom engine mounts made already, that was my planned next job.
ECU, standard inlet and engine loom for 4AGE, full car loom also included from donor MK1 MR2.
Westfield full loom never fitted just labelled up.
3.5 English new gaskets and hub seals in modified axle case.
Avo rear shocks.
Injection narrow fuel tank with return and tank straps.
Type 9 gearbox refurbed/painted box and new oils ready to go in.
Custom RWD motorsport 4AGE to type 9 bell housing, 3 gear levers for type 9 inc quick shift kit
New old stock RS2000 clutch fork
Handbrake and cables
Rear drums new shoes
All fuel and brake pipe done and fitted to chassis to IVA spec.
Brake master cyl
2 x steering columns allegro and mk2 escort style
Refurb mk2 steering rack. New steering rack mounts and poly bush
Mountney wheel and boss
Custom prop shaft type9 to English axle
Caterham seats and Caterham 4 point seat belts
4AGE custom equal length 4into 1 exhaust manifold
Stainless Westfield silencer
Westfield front shocks
Cycle wing brackets
Cortina front uprights, refurbed with new bearings, discs/pads etc.
Front cycle wings
Headlamps and Headlamp brackets
Side repeaters, brake lights indicator clusters. Several sets of indicators
Washer bottle
Westfield dash
Full set of VDO instruments speedo reads 900 miles. Surface rust on faces only.
All switches and warning lights
Whole bunch of xflow engine mounts and coils and xflow spares.
Polo rad and rad fan
Carpets full set
Hood
Screen glass & frame powder coated black & Frame uprights powder coated black.
Alloy side panels (as option instead of GRP tub) and alloy interior closing panels and alloy under tray panels for engine and boot under fuel tank.
2 x roll bars with back stays (RAC style)
Wiper motor & wipers
Windscreen fillet strips
Boxes and boxes of odds/sods and bolts/nuts/washers/rubber seals/gears/handbrakes/bushes etc.
Build stands included but engine stand not included.
Set of 14" rough alloy wheels to get it rolling.
More little bits, serious buyers come take a look. Located in Milton Keynes.
To finish needs built up (I believe almost everything is here to finish) and a paint/wrap or good cut and polish. I think less than £1k and time would see it all finished to a good standard ready for IVA.
For serious buyers I have 30 + pictures of box contents and close ups I can email across.
[Edited on 22/6/21 by Beggers]
Beggers
posted on 22/6/21 at 05:26 PM Reply With Quote
Beggers
posted on 25/6/21 at 07:43 AM Reply With Quote
SOLD
