the_big_1
| posted on 23/6/21 at 07:46 PM |
Faulty Shock Absorber
Hi guys,
Had a brand new set of Gaz shocks delivered this week.
When I opened the front shock box, there was oil staines. I asked the supplier who said they check all the shocks be before sending out. Fitted it all
to the car and when I lower the front, it spewed oil out.
snapper
| posted on 24/6/21 at 05:54 AM |
Post it back with photos…
I eat to survive
I drink to forget
Mr Whippy
| posted on 24/6/21 at 06:57 AM |
and a link to this thread
the_big_1
| posted on 24/6/21 at 06:59 AM |
Hi Guys,
Will do, hope they don't drag it out lol
Grimsdale
| posted on 24/6/21 at 07:07 AM |
guessing by the hole in the box, I suspect it's had a bit of a sideways knock during shipping, which has pinched the top seal.
| posted on 24/6/21 at 08:34 AM |
About to say - I'd suspect a failed seal allowing oil out.
Don't know if the shocks are re-buildable?
If they are I'd want to return them and have them rebuilt by Gaz (or better still replaced).
Fred W B
| posted on 24/6/21 at 10:57 AM |
in your first picture it looks like the rod is bent where is comes out the body
Mr Whippy
| posted on 24/6/21 at 11:38 AM |
Na I think that's just an optical effect caused by the springs, sure looks bent but...
Fred W B
| posted on 24/6/21 at 11:44 AM |
your blue lines make it look bent for sure, to me
adithorp
| posted on 24/6/21 at 12:18 PM |
When I was building I found slight staining around tops of Gaz shocks in the box and slight leak on first use. I asked them about it at Stoneleigh and
they said it does happen sometimes due to overfill during assembly. I was skeptical but
sure enough on leak in use once I'd wiped them down. When one did leak a year later they sorted a replacement pretty quick.
Def' appears bent but I'd guess it is an optical illusion caused by the reflection of the angled coils. Would taka a lot of force to bend
one.
http://jpsc.org.uk/forum/
procomp
| posted on 24/6/21 at 02:33 PM |
Hi. As mentioned above you do sometimes get a leak on top seal where piston rod goes into body but only very minor.
what you have there is a leak from the adjuster valve by looks of it.
it also looks like the main body at its base is making heavy contact with the mounting bracket. ?
I see your in Warwickshire, if you want to pop it over to me ( Brum J6 M6 ) i can check it over on the dyno and give a full report. FOC
Cheers Matt
the_big_1
| posted on 24/6/21 at 02:45 PM |
Hi guys,
Shipped via DHL back to the supplier. Was strange box had oil staining before I even started and seems to be leaking lower down rather than the top
seal.
It's not clashing with wishbone etc, just the angle I took the pic at.
