Author: Subject: AJ30 - X type or S type
magpies
posted on 2/11/21 at 01:40 PM Reply With Quote
Anyone know of the pitfalls in using a X type donor engine instead of the S type?
big_wasa
posted on 2/11/21 at 08:06 PM Reply With Quote
You won’t get the engine mounts.
Different sump, probably a good thing.
Different Inlet.
There is a large lump of pig iron in the “V” used for the transverse engine mount that you can’t remove with out taking a head of.
big_wasa
posted on 2/11/21 at 08:09 PM Reply With Quote
A question for you being a Tvr guy is there much call for the old 2.8 Cologne ? And any ideas on what money they fetch and good places to advertise one please ?
CosKev3
posted on 3/11/21 at 09:12 PM Reply With Quote
Pretty sure the xtype uses the water pump off the camshaft like the ST220 does,not sure if you can remove it and black it off or if it needs a cam swap erc
posted on 4/11/21 at 09:31 AM Reply With Quote
I'm no expert in these things, but isn't the Jag X-Type based on the Ford Mondeo of the same era?
CosKev3
posted on 9/11/21 at 01:23 PM Reply With Quote
They never fitted a AJ30 to a Mondeo though,the Mondeo ST220 engine is very similar but heads are different to the Jag AJ30
