Author: Subject: Throttle bodies - complete setup
chasmon
posted on 18/12/21 at 12:26 PM Reply With Quote
For sale: GSXR throttle bodies adapted to fit Zetec-E. Video of them running available.
Throttle bodies respaced with aluminium turned spacers and fuel rail connections
Custom CNC’d fuel rail inlet and return
Custom CNC’d adapters to mount to Webber Zetec manifold (tapered to match IDs)
Webber Zetec-E cast DCOE style manifold
Injectors from GSXR 1000 ~270cc/min
Vacuum take off
Secondary butterfly’s removed and blocked
Velocity stacks from GSXR 1300 TBs (two sets used to make one set of the longer middle ones)
ABS back plate mounted to velocity stacks in same way as air box would fits pipercross filter
Jenvey Aluminium backplate undrilled included also.
Silicone hose used to join throttle bodies to adaptors
Adapter joined to DCOE manifold with o ring seals (machined groove in face)
Original throttle position sensor
OEM injector and throttle position sensor connectors and cabling (Mande up from new connectors not salvaged)
Cabling has 1m+ on each wire in twisted pairs
Basically the whole injection setup to boot on with a gasket (not included) and run to your ECU and fueling.
Any questions just ask.
Can’t add pics from phone but happy to text them over to anyone interested.
Pics: https://www.facebook.com/media/set/?set=a.10158370369105846&type=3
[Edited on 18/12/21 by chasmon]
Deckman001
posted on 18/12/21 at 06:05 PM Reply With Quote
Hi ya, Am interested in the gsxr velocity stacks, what lengths are they as my bike carbs don't have any so I don't know what is the best length, also could you give me a price for the sets including a delivery unless your anywhere near the south east of England
Below are my basic set up of GSXR600SRAD carbs on a bogg bros manifold
Jason
[Edited on 18/12/21 by Deckman001]
chasmon
posted on 18/12/21 at 06:36 PM Reply With Quote
Hi, I’m only selling the complete setup as pictured all together. I have some velocity stacks kicking around but maybe one short of a full matching spare set. The setup listed uses the longer inner pair from two stock setups to replace the slotted type that came with the GSXR 1000s.
Deckman001
posted on 19/12/21 at 11:01 AM Reply With Quote
Fair enough, not a problem, many thanks for the advice though it is very much appreciated.
Jason
McFrancis
posted on 24/1/22 at 03:41 PM Reply With Quote
chasmon, Are the TBs still for sale? Do you have a price in mind?
McFrancis
