Author: Subject: Rebuild After Accident
stargoaly
posted on 12/8/22 at 02:49 PM Reply With Quote
Anyone had a similar experience.
I had a bit of an accident which meant that I needed to rebuild the car putting all the existing bits (Engine, gearbox, steering, diff, loom etc.) onto a new frame (replacing a few panels as well). I purchased the same frame as I had originally used. It was not an insurance job so car was not declared in any of the categories as a write off (probably wrong thing to have done). DVLA suggests this rebuild is OK to retain original plate, but is not clear on what else I should do. Any advice from your experience would be most welcome.
Regards Dave
virgin builder
cliftyhanger
posted on 12/8/22 at 03:46 PM Reply With Quote
As you have replaced the chassis with a new identical one, there is nothing to do.
Best to get a fresh MoT so it gets some sort of inspection.
stargoaly
posted on 12/8/22 at 05:07 PM Reply With Quote
Thanks, that's what I thought.
Regards
Dave
virgin builder
ReMan
posted on 13/8/22 at 10:18 AM Reply With Quote
Nothing to do and if your competent I wouldn't waste your money on an MOT
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
pewe
posted on 13/8/22 at 03:15 PM Reply With Quote
Presumably you'll need to transfer your old chassis number to the new chassis?
IIRC that needs to be stamped into the chassis or onto a plate that's welded on.
Slimy38
posted on 13/8/22 at 07:39 PM Reply With Quote
Even the best engineer would benefit from a second pair of eyes... if not an MOT guy then maybe a fellow builder?
We are only human after all...
Simon
posted on 17/8/22 at 12:38 PM Reply With Quote
Funny thing is that after my initial SVA, I put car back on trailer and noticed the examiner had missed a loose bolt on nearside lower wishbone...
Schrodinger
posted on 18/8/22 at 07:17 AM Reply With Quote
Do you mean you had both missed it up till then?
Keith
Aviemore
stargoaly
posted on 19/8/22 at 08:12 PM Reply With Quote
Guys, thanks for all you comments. Went in for MOT today and passed with flying colors.
virgin builder
Mike Wood
posted on 27/8/22 at 05:43 AM Reply With Quote
Congratulations - sounds like a job well done.
Have you kept a record of this chassis replacement to show a later purchaser (put in the car paperwork file with all the IVA paperwork and MoTs)
Have you cut uo the old chassis and removed its chassis number?
Mike
stargoaly
posted on 27/8/22 at 07:15 PM Reply With Quote
Yes I've kept all records including receipts of first and later purchase of chassis and my old chassis was cut up and scrapped after chassis number transferred.
Thanks for the advice.
virgin builder
