Author: Subject: Fiesta Alternator problems
Mr Whippy
posted on 18/8/22 at 11:33 AM Reply With Quote
My Fiesta which had a recent new alternator is being a pain. All was well until the battery light came on out the blue and off course while on holiday. I have a voltmeter in the car and I could see that it was not charging. So I pulled over and checked it and one of the connections on the positive battery terminals was loose, so lose that it seems to have been arcing and had got so hot that the plastic protective cover had melted all down the wire, lovely.
I cleaned up the terminals and tightened it all up. And all seemed well again, it was charging and the battery light went out. Then a few days ago the battery light came on again but it is still charging at between 14.5 - 14.8volts. It's strange as the battery light comes on, I start the car and the light goes out only to come on a second later and not go out till I turn off the engine.
I've checked all the terminals are tight and clean, checked all the fuses are fine, belt is new and tight and the battery is very good.
Any suggestions?? It's annoying as it was quite and expensive alternator and a sod to fit. It's a 2S6T10300DB btw.
Thanks in advance.
obfripper
posted on 18/8/22 at 11:59 AM Reply With Quote
The smart part of the alternator regulator is likely what has failed due to voltage spikes while the terminal was loose, have you got a ford specific code reader to check the engine management for codes? An obd reader may not read the code as it is not emissions related, this also means the engine warning lamp won't illuminate for the code being present either.
Dave
Mr Whippy
posted on 18/8/22 at 02:15 PM Reply With Quote
No I only have a cheapo reader although I do have a wireless OBD dongle I can try reading some codes from tonight.
posted on 18/8/22 at 03:06 PM Reply With Quote
What was the cause of it needing a new alternator in the first place?
Any previous issues to report which might help identify a fault?
adithorp
posted on 18/8/22 at 06:19 PM Reply With Quote
OBPfripper is probably right (nothing new there) with regard to voltage spikes.
I'd be having a word with whoever serviced it. Checking the security of battery terminals is a pretty basic check that any numpty ought not to miss.
http://jpsc.org.uk/forum/
gremlin1234
posted on 18/8/22 at 07:44 PM Reply With Quote
after reading any and all obd codes, I suggest you disconnect the battery overnight, so all the computers can reset. - yes literally turn it off and on again, but it often does work!
and just to note, obfripper and adithorp are both incredibly good with all their advice.
[Edited on 18/8/22 by gremlin1234]
Mr Whippy
posted on 19/8/22 at 06:00 PM Reply With Quote
I've already given myself a damn good telling off!
The original alt had shot bearings. I've tried clearing the codes, nothings working, think its knackered...
obfripper
posted on 19/8/22 at 06:14 PM Reply With Quote
You could replace the regulator rather than replacing the whole unit, i would guess at probably £20-40 to replace with a decent quality one, and you may need to get the soldering iron out for some internal connections.
A866X50372 should be the original regulator part number, have a look at some pics online and compare with yours to be sure.
As it is otherwise charging ok, i see no reason for other damage to the alternator.
You could check for any ac ripple using the ac setting of your meter, check from the +b terminal of the alternator to the casing, you want to see less than 0.5v once the meter settles down (the initial dc connection will show as ac for a few seconds). Above this would indicate a diode fault, they should be tolerant of at least 50v but is no guarantee.
Dave
[Edited on 19/8/22 by obfripper]
gremlin1234
posted on 19/8/22 at 07:46 PM Reply With Quote
Dave
or if he still has the one with the failed bearings, he could use that for parts.
