Benzine
posted on 19/1/23 at 04:42 PM |
Help with my wood
Hi LCBers,
I've got a load of fire door off cuts. 3 layers of hardwood sandwiched between MDF (or ply sometimes) covered with oak veneer. These are very
strong, and I'm going to make a decent workbench. Trouble is where they are cut looks naff, so I'm looking for the most locost way possible
of tarting them up. Iron on veneer, a skim of filler, quick sand and paint? Any other ideas that are cheap as chips used to be?
Photo of the edge face I'm talking about:
tegwin
posted on 19/1/23 at 04:59 PM |
Get a strip of soft/hardwood (Depending on budget) and glue it on the front edge... Will protect the edge of the sheet and finish it off nicely. I
don't like glue on edging, it chips and falls off in an active environment.
www.verticalhorizonsmedia.tv
Benzine
posted on 19/1/23 at 05:20 PM |
We process hardwood into edge strips for the firedoors at work. They look really good after they've been trimmed, sanded and varnished. Cost puts
and end to that idea though
[Edited on 19-1-2023 by Benzine]
gremlin1234
posted on 19/1/23 at 05:55 PM |
cover it with an aluminium sheet, (or steel or stainless)
cliftyhanger
posted on 19/1/23 at 10:25 PM |
I would just sand and varnish. I like varnish, especially using a very thin firts coat as it soaks in and binds the surface together.
If it has to look nice, get some wood edging, glue and pin it. I know you say cost is an issues, but it will be teh best looking by far.
roadrunner
posted on 20/1/23 at 06:55 AM |
If it was my bench top I would just sand the rough edges down or miter some wood edging around it and glue them on.
Benzine
posted on 20/1/23 at 05:19 PM |
Thanks for the replies! I hadn't thought about just sanding it and varnishing the edges. I'll do a test sand to see how they look, might
come up nice
posted on 22/1/23 at 09:02 AM |
Ditto
Usually done here with cheap wood and tacked on so it can be replaced if it gets bashed.
Mr Whippy
posted on 23/1/23 at 12:09 PM |
I'd use a router and an curved bit (one with a bearing to manage the depth) and round the edges as sods law you'll smack your knee off it at
some point...
trextr7monkey
posted on 29/1/23 at 01:31 AM |
some point...
A router would open up the possibility of taking a bit off the top so a piece of angle could be attached flush with top to protect and cover the edge.
Maybe use some old bed irons like that bloke who built a car for £250!!
Realistically a wooden lip will do the job
