Author: Subject: Chevy LS7 engine parts
Pat_T
posted on 5/4/23 at 02:29 PM Reply With Quote
Having a clear out and came across these which have got to be worth something to somebody!
In 2016 I imported a new Chevrolet Camaro Z/28, from new it was upgraded with cam and valve train upgrades to about 650bhp (from 505bhp standard).
For sale I have the original Chevrolet LS7 camshaft, valve springs, retainers, valve spring platforms and valve collets. There's also the standard LS7 thermostat (upgraded to a different 'stat).
These parts are a direct fit and upgrade to a number of the "lesser" Chevy small block engines. For example an LS3 should pick up about 40-50bhp through this mod... as well as increased valve lift & duration the engine will rev on to a higher speed. See www.motortrend.com/how-to/factory-gm-ls-engine-dyno-comparison
The parts are basically as new, out of an engine that just rolled off the production line and was then stripped down with under 500 miles on it. Since then they've sat in my loft, but been well packaged in oily greaseproof paper.
£160 posted (UK mainland) for the lot.
www.instagram.com/patroclueus
Pat_T
posted on 5/4/23 at 02:31 PM Reply With Quote
