quinnj3
posted on 30/4/23 at 09:33 AM |
MX5 Engine Mounting in Locost
Hi All,
I've just completed one of my engine mounts. I think they are fine as is but I just wanted others opinions on strength. Should I cap over them
to close them in? Engine is just a standard Bp unit putting out about 140bhp on a good day. I don't intend turbo charging any time soon. They
have been fab'ed from 3mm steel.
I have designed for full positioning of the engine. Left/right, forward/back, a couple of degrees of rotation and height can be adjusted with
shims.
  Engine mount 2
  Engine mount 3
  Engine mount 4
  Engine mount 5
  Lower engine mount
  Lower engine mount 1
motorcycle_mayhem
posted on 30/4/23 at 10:36 AM |
I made very similar looking open brackets from 4mm mild steel to support a Perkins 4182 in a Land Rover, again a 3 bolt fixing in a similar place to
that on the crankcase you've pictured. No issues in use.
Pictures indicate a good visual quality of Mig welding. To me, no expert in anything, my opinion is worth nothing, I'd be happy with what
you've done.
pewe
posted on 1/5/23 at 01:08 PM |
I'd be inclined to horizontally cross brace those between the outer edges to stop the sides flexing outwards at their mid point under load.
Probably belt and braces but whilst they're accessible worth doing.
Nice welding BTW.
ReMan
posted on 1/5/23 at 03:33 PM |
Looks good to me. As above i'd just cap over to going the two outer edges for good measure
www.plusnine.co.uk
quinnj3
posted on 3/5/23 at 09:33 PM |
Thanks all. I'll take your feedback on board. For now I'm going to leave as is but I've plenty of time to change my mind before they
get painted/powder coated. What I think I will do is buy a heavier duty washer. The mudguard washer I have in is probably too light
[Edited on 3/5/23 by quinnj3]
bi22le
posted on 3/5/23 at 10:21 PM |
Personally 3mm steel sounds a little thin, but it looks about right on the pics. At a later stage you could just brace with a little rod. You
can't do too much as you will want access, not too just do the bolts up but often oil will settle on the mounts and you will want to wipe them
clean.
Another observation is the proximity of bolt holes to the welds. The stresses will radiate out from the bolt head landing, they are close to the welds
on 2 bolts which may crack the weld area. Keep an eye on them areas.
Please read my ring story:
