Author: Subject: FS: ford st200 inlet setup for jaguar v6
sdh2903
posted on 3/5/23 at 07:16 PM Reply With Quote
I have a complete inlet setup for sale for a jaguar aj30 v6.
-Mondeo st200 inlet manifold (genuine st200 with the bigger ports) all standard iacv ports taken off, welded and smoothed. Single 19mm hose port underneath for breather or iacv port.
-St200 throttle body, professionally rebored to 65mm, complete with a universal tps (can't buy the st200 one)
-Adapter plates to fit between upper st200 inlet to Jag lower manifold. These are a bit rough around the edges being totally honest but do work.
-Jag aj30 lower manifold
-Jag 2.1 v6 fuel rail (the simple one with no sensors)
-inlet elbow with port for air temp sensor and port for breather or iacv.
-ramair cone filter (choice of 2)
£200 (happy to post for £10 extra)
Inlet1
Inlet1
Inlet2
Inlet2
Inlet3
Inlet3
Inlet4
Inlet4
mgb281
posted on 4/5/23 at 08:00 PM Reply With Quote
I must say that is a bargain for someone, to buy those individually would be double these days. Out of interest what are you using instead or are you not using the AJ30 engine now?
sdh2903
posted on 5/5/23 at 07:13 AM Reply With Quote
Yes it is indeed! I think the throttle body rebore was 150 quid all on its own.
Yes still have an aj30. I've just swapped to throttle bodies.
40inches
posted on 5/5/23 at 04:32 PM Reply With Quote
I will be interested to see what difference ITB,s make Steve
[Edited on 5-5-23 by 40inches]
sdh2903
posted on 6/5/23 at 08:33 AM Reply With Quote
Hi Dave. Difficult to make a direct comparison as I also fitted a new crate engine along with the ITBs.
But at the Dyno the car made an additional 24bhp and lost 2nm of torque Vs the old engine with plenum setup. Figures ended up at 234bhp and 282nm at the hubs (hub pack Dyno)
Partofthechaos
posted on 9/5/23 at 07:45 AM Reply With Quote
Definitely intersted! I will send you a message.
sdh2903
posted on 13/6/23 at 08:31 AM Reply With Quote
This is now sold.
To the person who messaged me recently about it. Apologies my fat fingers managed to delete the message whilst I was replying! Sorry!
