Author: Subject: Does ZETEC need ECU with Twin40s
barraw
posted on 4/2/05 at 11:15 AM Reply With Quote
Hi, I have a Westfield with a xflow engine. I'm looking at buying a ZETEC engine. Will I need to buy a ECU and loom for the ZETEC engine to work if I use my weber twin 40's? Does the coil need the ECU to work? thanks.
dozracing
posted on 4/2/05 at 11:25 AM Reply With Quote
Yes.
You need an ignition only ECU, something like a GEMS system, and a crack shaft pickup, the standard Zetec item will do.
Kind regards,
Darren
ChrisW
posted on 4/2/05 at 12:30 PM Reply With Quote
Or the cheaper options...
Megajolt Lt Junior live mappable ignition system. I can supply built and tested for £75 - just needs an EDIS module from a Fiesta mk3 (ten a penny in the scrapper)
or Escort Mk5 ESC module will run the car on it's own. Again, they're ten a penny in the scrapper and very easy to wire up, but downside is they're not programmable.
Chris
Mr G
posted on 4/2/05 at 04:51 PM Reply With Quote
Sounds like something you'd find in Soho
G
