grist_e
posted on 19/2/24 at 04:27 PM |
Tiger Avon Project/Parts (Job-LOT)
NOTE i am based in the South of Sheffield, South Yorkshire
I am selling for space reasons my unfinished Tiger Avon.
I have been collecting parts for a while waiting for a big build but alas this is not going to happen
Therefore i am selling the whole lot at a bargain price to move it on quick GRAB A BARGAIN all major parts described as per below and a few photos
included, however i have a full pdf with 50+ photos i can send to anyone who wishes to see more. or feel free to ask questions
Part Manufacturer Comments
- Rolling Chassis Avon Tiger Fully powder coated
chassis never registered or driven, (although it did have bodykit fitted at some point)
- standard wishbones Tiger Fully powder coated with Poly Bushes
- Coil over Shocks Pro Tech Adjustable front
- Hub assembly Ford
- Quick Rack 2.4 QR inc brand new track rod ends
- rear uprights
- Read Drums standard ford complete with shoes and springs
- Front Discs grooved
- Steering column rose jointed
- steering wheel Ford Standard sierra
- steering wheel Ripspeed with boss and horn buttons
- master cylinder Ford all brake lines fitted and
Power and drive gear
- Duratec 2.0 150 Ford in pieces, block glass blasted clean
- Fuel tank ADP Ali Fuel tank brand new never used
- Prop shaft
- half shafts Ford
- 5 speed gearbox Ford Standard Type 9
- Flywheel Ford Standard ST150 freshly skimmed
- Engine stand Blue
Interior
seats x2 GRP With Blue Pads
Random extra bits
Electrical
random wire, 2x relays, ignition lock & key injector mini harness standard coil pack and leads,Velcro straps, 8 way fuse board, fabric loom
tape x2, pvc loom tape, wire Flexi sheathing
Fuel
Facet lift pump, pressure regulator, filters and filter holders, various anodised AN fittings various mountings, rubber 2mm 3mm adhesive foam,
breather filter
Cash on collection £1500 already a bargain so unfortunately NO OFFERS!!!
  Chassis n wheels side view
[Edited on 19/2/24 by grist_e]
[Edited on 20/2/24 by grist_e]
Craig
One man on his mission to spend as long as he can in that garage till completion or divorce whichever comes soonest
posted on 20/2/24 at 05:46 PM |
Your location got cleared at the reset.
grist_e
posted on 20/2/24 at 05:54 PM |
Updated main post with address details, thanks for highlighting.
Craig
Mr Whippy
posted on 21/2/24 at 09:46 PM |
I think that is a fantastic price for so much. However as the engine is in bits it might be worth detailing a bit more on what is needed to assemble
and get it running. I have those exact stands, I'd be scared to put my whole weight on them, far less a car
grist_e
posted on 22/2/24 at 11:51 AM |
So the engine was bought complete by me from ebay as an 80k miles running but "Burning oil" condition I didnt hear it running.
It arrived complete on a pallet with quite a few ancillaries (injectors, coil etc)
my intention was to strip it down clean it up re-ring it and run it as is.
so i carefully dismantled and arranged all parts in order in their boxes etc and visually inspected for wear (didn't see anything obviously
concerning but again didn't exactly taken a micrometer to any of the parts.) needless to say i was confident enough to send the block and head
away for glass blasting (for vanity purposes more than anything ) and start to bbu parts
Whilst looking for replacement rings i found a seller (performance engine builder) who was removing the whole pistons/rings/rods from brand new crated
engines which he didn't need thus i bought a set of those, i also purchased a Raceline Alloy sump and new Mains/thrust washers. and some millers
assembly paste (all included)
the sump carries more oil than s standard sump and uses the Duuratec 2.3 oil pump which i had not yet bought.
I also had the flywheel skimmed (cant remember how much was taken off but bare minimum to just clean it up)
so for re-assembly i was going to check and measure tolerances and wear then buy new, head gasket and valve stem oil seals, may have bought a new cam
chain (probably not...) new rod, big end and head bolts new crank /cam oil seals. the 2.3 oil pump and windage tray for the new sump and just
assemble from there.
I may have forgotten some details but happy to add any further details/pictures if needed.
Craig
J90rdn
posted on 4/3/24 at 10:39 AM |
Would you sell the quick rack separately?
grist_e
posted on 4/3/24 at 04:02 PM |
Hi Jordan Thanks for the enquiry, at present i would like to keep it all together (my thinking is that someone could actually buy the lot and sell off
the bits they dont want separately and make a tidy profit...
That said obviously If it sits too long without any takers as a Job Lot i may consider selling parts off separate and if i do i will be sure to U2U
first.
Kind Regards
Craig
Craig
J90rdn
posted on 4/3/24 at 06:05 PM |
Thanks Craig - completely understand, and someone's getting an absolute bargain. Free bump.
HowardB
posted on 8/3/24 at 10:33 AM |
That is a bargain!
GLWTS
bttt
Howard
wowblaauw
posted on 9/3/24 at 01:03 PM |
U2 sent
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in
sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming...
Damn, What a ride!!"
grist_e
posted on 12/3/24 at 07:33 PM |
Tiger Avon Project/Parts (Job-LOT) SALE AGREED
Hi guys just to advise this is now SOLD subject to completion.
thank you for all the interest
Regards
Craig
Craig
