Author: Subject: Tillett seats, Pi dash, Racetech gauges
frodo_monkey
posted on 29/3/24 at 06:16 PM Reply With Quote
Hi there,
I’ve upgraded my Ginetta to Jenveys, an Omex ECU and a Dash2 Pro… so the stuff on there before is up for grabs! Was all fitted to the car and working until the end of 2023.
- 2x Weber 45 DCOEs (type 152) on a Zetec inlet manifold, freshly serviced and with a throttle linkage. SOLD
- MBE 967 serial port ignition-only ECU with loom and connectors for Zetec coil pack/crank sensor and throttle position sensor. Was mapped for a 190bhp 2.0 silvertop by Northampton Motorsport, will throw in a MBE serial cable with USB adaptor. Software is available free online. SOLD
- Pi Omega D2 Pro dash with shift light module. Comes with loom, an IR beacon, a GPS puck, an oil pressure sender and 2x thermocouples for oil/water temperature. Manuals all available online. £400
- 52mm Racetech mechanical gauges, one oil pressure and one water temperature. £30 each
- 2x Tillett low-back W1i seats. Base-mounted, one with a runner. Used fair condition. Bought them secondhand from someone with a Fury but can confirm they won’t fit a Ginetta G20! £450 the pair
Collection from South Wales between Chepstow and Monmouth, postcode NP16 6NA (or I work in Bristol and could bring them with me). May be able to post by arrangement.
Si
[Edited on 30/3/24 by frodo_monkey]
"Racing is life. Anything before or after is just waiting."
frodo_monkey
posted on 30/3/24 at 02:08 PM Reply With Quote
Carbs and ECU sold
gsr88
posted on 8/4/24 at 10:30 PM Reply With Quote
Hi
Can you share some pics of the gauges please?
frodo_monkey
posted on 9/4/24 at 10:26 AM Reply With Quote
Originally posted by gsr88
Hi
Will take some tonight.
gsr88
posted on 26/4/24 at 08:52 AM Reply With Quote
any luck with the gauges?
frodo_monkey
posted on 27/4/24 at 02:33 PM Reply With Quote
Sorry yes, I did take the pics then appear to have forgotten…
[img]https://flic.kr/p/2pMGTki[/img]
[img]https://flic.kr/p/2pMKe1L[/img]
They’re both 1/8”NPT, the water temp gauge is 4ft and the oil pressure gauge 3ft.
