Author: Subject: LED Indicators / relay - not working, anything I don't know?
trevw
posted on 13/6/24 at 09:56 AM Reply With Quote
I've converted to led lights as part of a rebuild - I bought an led flasher relay to go with my newfront and rear indicators (no repeater yet).. however I am still seeing the indicators only coming on and staying on with the hazards switch and no response with the indicator stalk..
I've got a bunch more investigation to do when I get the car back (having an exhaust made currently) but I wanted to check if the below items should work together or if there's something I don't know? I think resistors can be used instead of a special relay when converting, are the led resistances are relevant if you do go for a dedicated led relay?
Could it be something to do with the dashboard lamps if they are in series with the indicators as they are normal bulbs..? In which case do I need the three pin relay with a separate take off for them?
Flasher relay: https://www.carbuilder.com/uk/red-2-pin-led-flasher-relay
Front indicators: https://www.carbuilder.com/uk/chrome-miniature-amber-stalk-indicators-26mm
https://www.bowerspartsonline.co.uk/lighting/rear-lighting/led-rear-combination-lights/55mm-round-inner-led-clear-rear-stoptail-light-for-98mm-combina ble-lights-lamps
Thanks!
Trevor
padrc66
posted on 13/6/24 at 11:57 AM Reply With Quote
i found that i still had to put resistors in series with the front indicators and side repeaters to get them to work reliably, even with an LED relay. i used 2W 100 ohm resistors that i happened to already have - they've stayed working for 5 years so far.
trevw
posted on 13/6/24 at 12:24 PM Reply With Quote
padrc66, thanks! Will try that, no issues with the rears?
SteveWalker
posted on 13/6/24 at 02:12 PM Reply With Quote
I tried resistors and I tried an LED indicator relay without resistors - the latter was just within the high end of the allowable flash rate, but still felt far too fast. In the end, I bought an indicator relay that had an adjustable potentiometer built in (https://www.amazon.co.uk/dp/B0CGZ3D9CD), ran without resistors and turned it to just the speed I wanted.
I was a bit dubious due to the bad English on the relay, but it does function as intended.
trevw
posted on 13/6/24 at 04:17 PM Reply With Quote
Interesting! Will take a look and might give those a try..
padrc66
posted on 13/6/24 at 04:21 PM Reply With Quote
it just needed a bit more load - doesn't matter where as they are all connected together. i tried just in the side repeaters first and then added to the fronts later to get it to be reliable.
i've changed to one of these now so probably don't need the resistors, motogadget mo.unit: mo unit blue
brilliant bit of kit that replaces most of the relays and fuses, allows keyless go, gives indicator cancelling and allows momentary push buttons to control ignition, lights, indicators, etc
trevw
posted on 17/6/24 at 04:42 PM Reply With Quote
Interesting piece of kit.. am nearly all re-wired now, but will bear that in mind for the future.. though I don't understand how it works! :-)
jacko
posted on 17/6/24 at 04:57 PM Reply With Quote
I believe in the old days people put a 21w bulb in the line for your problem
[Edited on 17/6/24 by jacko]
555
